Big Cast Bracket
this thread has 5 replies and has been viewed 967 times
Old 08-26-2017, 08:20:06 PM
Caleb Carpenter Caleb Carpenter is offline
Images: 1
Default Big Cast Bracket
We have a big bracket for a Rumely and wondering if there are anymore out there. We know what its for but wanted to see if anybody wanted to play the game "Whats its purpose"
Not a part # on it but it is a factory item.
ID:	289493   Click image for larger version
ID:	289494   Click image for larger version
The Following User Says Thank You to Caleb Carpenter For This Post:
Old 08-27-2017, 01:48:43 AM
Stuart Landry Stuart Landry is offline
Default Re: Big cast bracket
Could this bracket fit on a steamer, Perhaps between the boiler and steam cylinder ?
What are the other parts on the load for ?
Old 08-27-2017, 09:39:43 AM
Images: 1
It fits an E oilpull and should fit a B also.
Old 08-27-2017, 05:00:57 PM
AultmanTaylor AultmanTaylor is offline
Replacement engine mount?
Old 08-27-2017, 08:40:09 PM
Images: 1
Default Re: Big Cast Bracket
Aultman Taylor your close enough. Its more of a fix than replacement. Its a factory offered piece to fix the broken crankcase legs. It was bolted to this tractor but the installation was never finished.
The Following 5 Users Say Thank You to Caleb Carpenter For This Post:
Old 08-28-2017, 02:28:31 AM
Would they mount it next to the old one or grind off the old one?
Briggs cast iron bracket for flat bottom gas tank Dengine Small Air Cooled Gasoline Engines 2 03-02-2013 05:03:28 PM
Broken Sub Base: Mold, Cast, Cast Iron Weld DaveTexas Antique Gas Engine Discussion 24 03-17-2011 12:00:46 AM
What model Briggs uses Cast Gas Tank Bracket 21978 mschreiber Small Air Cooled Gasoline Engines 2 02-17-2011 03:49:15 PM
To make new valves - cast steel / cast iron Edwin Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 12 05-02-2009 12:53:18 AM
What is this cast iron bracket Steve Kunz Antique Gas Engine Discussion 1 02-10-2009 09:11:47 AM
