What is this mystery winch thing?
this thread has 57 replies and has been viewed 6955 times
Old 09-01-2017, 09:39:53 PM
Default Re: What is this mystery winch thing?
Looks to have been a tricycle or row crop tractor
Old 09-01-2017, 09:51:41 PM
Jacob WI Jacob WI is offline
yes Phil, cool things have a way of finding me, LOL! And yes I'd LOVE to drag home ALL the cool old junk, er I mean valuable antiques I find, but I have to limit myself to a certain point, ya know?
I very much like a mystery, and this still really has me stumped.
Doing some more Google searches of pull type combines, oil rigs, well rigs, etc... and I find things SIMILAR to this mystery thing, but nothing matches, or makes sense (at least to me).
Pat, the well rig of some sort is what I keep coming back to myself. But the drive wheel chained to the pulleys is what screws that idea up for me. A well rig would be stationary correct? Can anyone confirm or deny that drill rigs would be like this? And if so, PLEEEASE explain it to me
This is driving me nuts, I don't like it when I can't figure something out
Old 09-01-2017, 11:58:40 PM
halcon halcon is offline
I am thinking more along the line of a hay or sheaf loader. Do you know if there is an idler gear between the two visible gears. There is a shift mechanism that appears to slide the pulleys into mesh with either the chain or the gear drive. If it has idler gears that would reverse the pulley rotation when shifted.
The Following 2 Users Say Thank You to halcon For This Post:
Old 09-02-2017, 12:46:38 AM
Yes, that is how the pulley shift mechanism works. I should have explained it better.
If it is slid one way it rotates clockwise, if slid to the other way it rotates CCW.
Then each pulley is independent of the other, meaning as far as I can see one side of the machine is completely independent of the other side.
A hay or sheaf loader is something I had not considered, and at this point I'll take any suggestion I can get.
I also briefly thought about a steam engine cable plow thing of some sort, but don't really think that is the answer either?
---------- Post added at 11:46:38 PM ---------- Previous post was at 11:18:08 PM ----------
Another thing that keeps throwing me off is the width of this thing. It is super narrow. Most old machinery is super wide. Like hay loaders, pull behind combines, pull road graders, even smaller things have room between the frame rails for "stuff" like in potato diggers, etc... heck even engines need a little room.
The narrowness of this has got to be a clue
Old 09-02-2017, 08:20:21 AM
ajs2744TC ajs2744TC is offline
Maybe a Short Turn tractor or as simple as a tree planter. Never seen a Short Turn in person but small pic shows a lever lift setup and three wheels. Maybe! That's a wide range of thoughts. If it wasn't a tractor would be great start to a well made homemade one if you were to build one.
The Following User Says Thank You to ajs2744TC For This Post:
Old 09-02-2017, 10:14:20 AM
More good ideas Adam, the bogie wheel is similar to a Square Turn tractor, though not it from the pics I have seen.
And the thought of making a home made tractor out of it HAS crossed my mind through this process, just what I need, another project
Talking it over with a friend this morning, we have a plausible idea. If the whole rig was pivoting around a central pivot point by the rear end, and the bogie wheel was up front, a team of horses could pull this thing in a circle.
Then the drive wheels would be spinning, and the pulleys too, so a well for example could be pulled?
That make sense?
Old 09-02-2017, 10:38:34 AM
Russ Hamm's Avatar
Images: 1
I'm thinking thats a push header or push binder. Only thing that makes me hesitate to be sure is the steerable small wheel.
Old 09-02-2017, 10:45:30 AM
TractorDom's Avatar
TractorDom TractorDom is offline
it is part of an early Fordson tractor early 1900's
see this video: https://www.youtube.com/watch?v=5UWJn2wD9JQ
Old Habits like old iron die hard
The Following 5 Users Say Thank You to TractorDom For This Post:
Old 09-02-2017, 11:33:53 AM
That Fordson bogie wheel is again similar, but not a dead match, and the rest is different too, but keep the ideas coming, I'm all ears!
If it were some type of binder or whatever, how does that explain all the pulleys And again, I'm thinking it is too narrow for those ideas?
But I don't know what it is, so I can't definitively shoot down what is isn't
hummmm...
Old 09-02-2017, 12:01:22 PM
continentalk4 continentalk4 is offline
How about a pull ripper or subsoiler ? The pulley arrangement would raise and lower
the shank(s).
The Following User Says Thank You to continentalk4 For This Post:
Lorrys' new winch cobbadog Smokstak Down Under 6 07-09-2015 02:16:52 AM
Help Identify Winch looking thing Dustin D Ehli Farm + Industrial Antiques and Collectibles 5 07-10-2011 06:06:52 PM
Hydraulic Winch Gary A. Craig Trucks, Trailers and Hauling for Shows 2 03-30-2010 09:02:28 PM
Need help with winch JHFoster Antique Marine Engines and Outboard Motors 1 10-22-2009 03:53:20 PM
Look at my Olds 8 hp and winch Tom Guinn Antique Gas Engine Discussion 24 09-26-2008 09:05:06 PM
