Mystery Gang Plow
this thread has 8 replies and has been viewed 1119 times
Old 09-01-2017, 07:38:12 PM
Jacob WI Jacob WI is offline
Default Mystery Gang Plow
Hi all,
I found this mystery gang plow in my adventures, and am wondering if anyone can ID it, and tell me if it is worth rescuing or not?
Basically all the important parts are gone, just the basic frame and wheels left.
Cast number in the front wheel hubcaps is 696 (or 969 depending on if you're standing on your head or not)
The drawbar end has a big horseshoe shaped part.
I don't know anything about these old gang plows, so educate me!
What is it?
ID:	290069   Click image for larger version
ID:	290070   Click image for larger version
ID:	290071   Click image for larger version
The Following User Says Thank You to Jacob WI For This Post:
Old 09-01-2017, 08:01:23 PM
Glenn Gieszler Glenn Gieszler is offline
Default Re: Mystery Gang Plow
I wish you had better pictures but it looks like it had a power lift on it, possibly Avery?
Old 09-01-2017, 08:11:37 PM
Yeah, sorry, it was VERY hard to get pics of, there is a huge pine tree basically on top of it!
I can go get more pics if there is something specific that everyone needs to see to ID it. I was hoping you guys could tell from these few shots
Old 09-01-2017, 08:40:28 PM
Most likely a John Deere as they were the most common plows around.Their does not seem to be much left of it.More/better pictures might help
Old 09-01-2017, 11:37:21 PM
halcon halcon is offline
You have found a portion of an Avery power lift engine gang plow. It appears to have been a 8 or 10 bottom plow.
The Following User Says Thank You to halcon For This Post:
Old 09-02-2017, 10:34:11 AM
Russ Hamm's Avatar
Images: 1
It is absolutely worth saving, if nothing else somebody may need a part or two and you just don't find parts for these, you find whole plows. And you won't find as many whole ones as you will later plows, so it's value is mostly in it's number.
Old 09-02-2017, 09:20:06 PM
Joe P Joe P is offline
I have an Avery power lift missing lots of parts. I could use any extra parts if you get them.
Joe Peternell
320-250-3289
The Following User Says Thank You to Joe P For This Post:
Old 09-12-2017, 09:59:10 PM
Got the plow drug out in the open where we can have a better look at it now. Took a little video for you guys.
So is this an Avery then? I'll be giving you a call one of these days when I get time Joe to see if you need this for parts? Or if anyone else might? Let me know, thanks!
The Following 3 Users Say Thank You to Jacob WI For This Post:
Old 09-12-2017, 11:04:19 PM
Yes, give me a call sometime.
Joe P
Who Built The Best Steam Plow - Engine Gang halcon Steam Stationary Engines, Traction Engines, Steam Boats 76 02-16-2018 09:27:55 PM
John Deere Gang Plow Color Demoman Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 08-19-2016 10:24:36 PM
Case Sattley Engine Gang Plow tomv Farm + Industrial Antiques and Collectibles 3 12-03-2015 11:50:52 AM
John Deere gang plow Matthew Harvey Steam Stationary Engines, Traction Engines, Steam Boats 17 06-12-2013 09:41:21 PM
John Deere Gang Plow Castings TracksNIowa Steam Stationary Engines, Traction Engines, Steam Boats 0 11-03-2011 02:43:06 PM
