1929 Deere D, differential gears move when applying emergency brake
this thread has 4 replies and has been viewed 468 times
Old 09-04-2017, 04:14:53 PM
bmklawt bmklawt is offline
Default 1929 Deere D, differential gears move when applying emergency brake
Had the transmission cover off today and notice when I apply the emergency brake the differential gear shaft and gears, I think these are the differential gears, move forward and up slightly (1/16") is this normal.
Your help is greatly appreciated,
Bruce
Old 09-04-2017, 08:14:47 PM
OldThresherM OldThresherM is offline
Default Re: 1929 Deere D, differential gears move when applying emergency brake
My '29 D does the exact same thing.I noticed it when I was flushing out the transmission.I believe it is caused by wear in the bearing quills of the shaft.Maybe the experts could chime in on whether it is a big deal or not.How noisy is your transmission?
Old 09-04-2017, 08:30:06 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
My 27 does it as well. I've never worried as it doesn't get much use. I never looked but does it have Timken tapered bearings or flat roller Hyatt's in those early Ds?
Old 09-04-2017, 08:53:57 PM
It looks like a flat roller in the diagram.According to the parts book,it was the same in all of the unstyled d's.
The Following User Says Thank You to OldThresherM For This Post:
Old 09-04-2017, 08:57:17 PM
FWurth's Avatar
One Millionth Post
Images: 4
I guess that the reason. Those type are never real tight and you cannot do much with them other than replace.
Emergency Brake - 40's Dodge Truck Diagram mag473 Antique Autos and Trucks 1 06-14-2016 10:25:44 AM
1928 GMC T20 TRUCK Emergency Brake Lever "ratch" configuration unknown. GMCtrucker Antique Autos and Trucks 2 09-02-2015 06:23:26 PM
How do i move out the tire On a John Deere G Johnny D 1837 Antique Farm Tractors 3 05-16-2014 01:15:26 AM
1929 20-35 brake band split51 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 10-03-2009 10:56:06 PM
