28-50 Hart Parr fan shaft problem
this thread has 1 replies and has been viewed 437 times
Old 09-06-2017, 09:43:53 AM
NDFalthead NDFalthead is offline
Default 28-50 Hart Parr fan shaft problem
Had a new fan shaft made with new bearings.
Put it together and installed it.
PROBLEM- it is very difficult, takes a lot of pressure, to move fan shaft friction wheel to flywheel.
Ideas or suggestions on how to fix problem??????????
THANKS for helping.
Old 09-06-2017, 01:43:18 PM
Default Re: 28-50 Hart Parr fan shaft problem
Were the bearings replaced with the correct bearings?
The original bearings are self aligning to allow for the swiveling action.
Does the shaft turn freely when in the relaxed position?
If so does it start to tighten as it moves toward the flywheel?
Hart Parr 15-30A Pat Bayer Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 19 05-31-2015 11:16:58 PM
Hart Parr 12-24 Pat Bayer Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 18 07-05-2014 09:23:52 PM
Hart Parr 18-36 Phil Johnson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 08-17-2008 12:20:04 AM
Hart Parr 30-60 Lawrence Woolf Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 03-10-2006 03:21:28 PM
18/36-Hart-Parr d.j.baisch Antique Engine Archives 7 11-15-2002 01:22:01 AM
