Briggs Model Y Spark Plug Wire
this thread has 3 replies and has been viewed 332 times
Old 11-17-2018, 04:02:19 PM
Cnew Cnew is offline
Default Briggs Model Y Spark Plug Wire
Iíve got a Briggs model Y that I just got to fire this afternoon but noticed shortly thereafter that the spark plug wire is nearly severed in half. Anyone know where to get a new wire or a high quality reproduction?
Old 11-17-2018, 05:43:13 PM
Ray Cardoza's Avatar
Ray Cardoza Ray Cardoza is offline
Default Re: Briggs Model Y Spark Plug Wire
get a couple feet of Copper cored wire. not the modern carbon wire. pretty much any autostore should have it
Old 11-18-2018, 01:51:19 PM
Brian Lynch's Avatar
Brian Lynch Brian Lynch is offline
Images: 23
Yeah, the 7mm copper core wire does the trick. Strip off about a half inch on the end that will be on the coil. Take some solder and tin that end. Here's why- Trying to solder the wire onto the terminal will cause damage to the coil windings. Thread your tinned end through the coil terminal and bend it around the terminal. I put a small amount of silicone sealer over that connection to prevent flash over.
"May your walk through life have no dogpiles in it" -Brian Lynch
Old 11-18-2018, 02:19:48 PM
Thank you both for the recommendation and tips on installing to the coil, thatís great insight to know ahead of the operation!
Briggs and Stratton Model A Spark Plug? CycleKartBow Small Air Cooled Gasoline Engines 6 09-15-2016 01:55:37 PM
Briggs WMB Spark at Wire but Can't See Spark at Plug KubotaDiesel Small Air Cooled Gasoline Engines 15 05-05-2014 11:15:05 AM
Model H Rumely spark plug wire routing 2030rumely Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 03-18-2014 03:54:53 PM
Briggs WI Spark Plug and Wire Zim Small Air Cooled Gasoline Engines 7 03-20-2011 01:19:40 PM
Spark Plug For Briggs Model ZZ Trashman Small Air Cooled Gasoline Engines 7 12-22-2007 04:42:39 PM
