O&r engine fuel pump
this thread has 3 replies and has been viewed 327 times
Old 11-25-2018, 05:09:27 AM
wfb26 wfb26 is offline
Default O&r engine fuel pump
Help needed I bought a O&R 1hp engine and the fuel pump is not working I took the top of and all the parts fell out I do not know how it goes back together there is a small roller and I do not know where it goes has anyone got photos of how it should be or can you tell me please thank you Roger
Old 11-25-2018, 09:21:13 AM
K-Tron K-Tron is offline
Default Re: O&r engine fuel pump
Basically you locate the stainless steel ball bearing (inlet needle) in its hole, then you half install the spring steel two leg retainer (from the inlet needle side), then install the inlet valve arm which presses against the diaphragm. The little roller goes in the small channel opposite the inlet needle, as it provides additional spring to the spring steel retainer clip. I use a plastic pen cap to push the spring steel retainer in place. Just work the spring steel retainer slowly. With an x-acto blade, carefully pop up each leg of the spring steel retainer up over the roller. The spring steel retainer should be almost flat, when fully installed, with the two legs riding up over the crest of the small roller.
Old 11-25-2018, 09:40:30 AM
Thanks for the reply I will have a go at it
Old 11-25-2018, 11:43:11 PM
Mike in NC's Avatar
Images: 74
Try this link. There might be some helpful info.
Ohlsson Rice Manuals
SmokStak Member #28
IHC M Engine Fuel pump ID help Lloyd W. Carburetors, Mixers, Fuel Pumps and fuel delivery 2 07-07-2014 08:48:13 PM
Novo fuel pump and engine oil pjjms Antique Gas Engine Discussion 1 02-29-2012 02:38:25 AM
2-71 loss of fuel pressure from fuel tank-check valve? or bad fuel pump? Walter J. Generators & Electric Motors General Discussion 18 08-24-2011 09:22:40 AM
Engine fuel pump rebuild kit for 7.5kw-JB krup94 Onan Generators 6 03-06-2009 09:25:58 PM
RDJF engine fuel pump fayroumf Onan Generators 6 02-22-2006 02:15:52 AM
