AH47 ignition parts needed
this thread has 7 replies and has been viewed 453 times
Old 12-02-2018, 09:56:32 PM
backyardmechanic93 backyardmechanic93 is online now
Default AH47 ignition parts needed
Looking for a coil for a power products AH47 gas engine. Possibly points & condenser as well. If anyone knows where I might find parts I would appreciate any help. I can be reached at 306-720-0129 (Saskatchewan). Thanks
Old 12-03-2018, 12:19:43 AM
Default Re: AH47 ignition parts needed
what the hell, try ebay….
Old 12-03-2018, 01:16:28 AM
K-Tron K-Tron is offline
There should be a small tag (about the size of a quarter) attached to one of the four bolts which secure the cylinder to the crankcase. There will be a number stamped into it. Post that number. I can give you the part number of the coil, points & condenser if the spec number from that tag is posted. I wish Power Products listed parts based on model number, but that is not the case. If your engine has a long stamped aluminum tag riveted to the blower shroud, the spec number could also be there.
Old 12-03-2018, 10:30:02 AM
gdstew gdstew is offline
Also note if Phelon or Wico ignition
Old 12-04-2018, 01:53:09 AM
Thanks, I will get that number by the weekend.
Old 12-18-2018, 08:04:16 PM
The tag reads: T-1042 I
2442357
---------- Post added at 08:04:16 PM ---------- Previous post was at 08:03:09 PM ----------
It's a Phelon
Old 12-22-2018, 09:06:17 PM
T-1042 is definitely AH-47, Power Products unfortunately lists the "magneto" as one assembly which includes the ignition housing, coil, coil laminations, points and condenser. My book lists seven different Phelon ignitions for this engine. 610453, 610366, 610555, 610552, 610454, 610545, 610597. I do not know how to identify which your particular engine uses. Can you post a picture of what you have.
Old 12-23-2018, 02:40:49 PM
For a T-1042I engine, I came up with ignition assy 610493. Unfortunately, I misplaced the ignition/carb section book that shows the breakdown for that assy. I'll keep looking.
If your points and condenser are Phelon, there should be a "FG" number stamped in them. If you can find a "F" number on the plate that everything bolts to, I can look up that info in my Phelon book.
Some of our manuals were close to 60 years old, selling the building and moving everything out has made quite a mess of things.
Cushman Model 21 Type X (mag fired) Timing and Ignition Parts needed. KubotaDiesel Antique Gas Engine Discussion 2 10-13-2016 06:02:59 PM
THD parts needed for electronic ignition oldmansimek Wisconsin Engines 5 06-02-2014 08:08:42 AM
Power Products AH47 help thambach Small Air Cooled Gasoline Engines 22 12-29-2013 08:42:00 PM
ONAN OCCKB-3CR Ignition parts needed mmland5 Onan Generators 1 08-26-2010 10:59:23 PM
Power Products AH47 info needed pioneer fan Chain Saw Collectors 4 08-07-2009 11:53:19 PM
