Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Drag Saw Collectors
Drag Saw Collectors Water cooled drag saws; Hercules, Ottawa, Wade, Vaughan, Witte, Timberwolf and Multnomah
Drag Saw Collectors
4hp Vs 5hp Ottawa Drag Saw
this thread has 5 replies and has been viewed 2466 times
Old 09-20-2015, 05:51:05 PM
BigGoomba's Avatar
BigGoomba BigGoomba is offline
Default 4hp Vs 5hp Ottawa Drag Saw
I bought a Ottawa log saw at auction last weekend, it's rough but fairly complete. The saw mechanism is free and I can turn it using a monkey wrench on the large hex nut.
It's a 4 hp with a serial number TE9981.
Most of these that I have seen were a 5hp but look pretty much the same as this one. Are there any differences between the 4 hp and the 5hp? Did they just up the working Rpm rating?
I have read a little bit about them. Guessing this would have been built in the mid to late 20s. Did make both 4 and 5 hp engines at the same time or did the 5 hp replace the 4?
-Steve J
The Following User Says Thank You to BigGoomba For This Post:
Old 09-20-2015, 09:31:43 PM
OrgWayne OrgWayne is offline
Default Re: 4hp Vs 5hp Ottawa Drag Saw
Brooks has a few every year , can You wait /
Wayne
Old 09-21-2015, 12:13:38 AM
johnk907 johnk907 is offline
There are differences. I have a 4 horse with two flywheels and a different mag than my 5 horse Ottawa which has one flywheel.
John
Old 09-21-2015, 07:10:06 PM
Weezer Weezer is offline
I have both and cut with both at the Rough & Tumble reunion this year. The 5hp cuts at a slower speed, I guess due to more torque. The only difference that I have found is the piston diameter. Found it's better to cut slow, we're doing demonstrations, not feeding the mill. They tend to be kind of violent at speed, make sure it's chained good. We made cribbing from railroad ties to secure the logs. The bigger the log, the better, gives em something to chew on. Mine are single flywheel. The clubs 2horse Whitt is a much nicer saw to operate, if I had to do it again I would rather have one of them. Good luck and be safe!
Old 02-23-2018, 02:42:38 PM
kicknmule kicknmule is offline
BigGoomba , could you tell what it is that dates your saw with serial number 9981 to the mid to late 20’s ? I have two / one with the number 8287 and the other 10028. Also do you have anymore pictures of saw in the attached photo in your above post? Thanks. Mike
Old 02-24-2018, 03:02:05 PM
My son had a 4 HP, single flywheel. It sure was a bouncy rig! Try to cut anything under 6" in diameter, and it would spin in circles! I had a headless witte, 2 HP rig, and it hardly ever moved!
Ottawa ES Drag Saw AKMark Antique Gas Engine Discussion 0 03-01-2013 01:40:22 PM
ottawa drag saw rolfengine Antique Gas Engine Discussion 0 04-23-2012 05:57:13 PM
5 Hp Ottawa Drag Saw tjohnson Antique Gas Engine Discussion 1 06-30-2009 05:28:51 PM
Ottawa drag saw Tim Antique Engine Archives 0 07-12-2002 10:38:06 PM
ottawa drag saw ? robert hudson Antique Engine Archives 0 05-25-2002 07:57:31 PM
