My first project: Briggs and Stratton 4
this thread has 48 replies and has been viewed 3220 times
Old 08-13-2016, 11:58:57 AM
SteveK SteveK is offline
Default Re: My first project: Briggs and Stratton 4
CKB if the tank seam does not leak I would leave it alone(depending on the scale of resto you are doing). Probably will not leak at this point but trying to straighten it may crack the solder. I assume you know you have to loosen the jamb nut on the exhaust pipe with a punch or chisel before the nipple will unscrew from the head?
I started my collection with a Briggs WI.
On the level
Old 08-13-2016, 03:12:02 PM
CycleKartBow CycleKartBow is offline
Originally Posted by Vanman View Post
Looking good! Curious - did your flywheel have an aluminum key or a steel key?
As I understand it, they all supposed to have aluminum keys. Right now I have two Model ZZs apart, and both had steel keys. One of which likely substantially increased the damage sustained.
Keith
Hey Kieth,
I didn't stick a magnet to it, but considering the weight of it, it's Steel
I would like to make it look good as new, after cleaning up the block last night, I found one of the mount tabs on the base of the engine was broke off (before cleaning, I couldn't tell and thought it was odd it only had 3 tabs).
I did try that with a punch, but it still didn't move. I may attempt the chisel today, I figure the chances of the jamb nut surviving the removal are pretty slim at this point...
I would like to see if I can pop the breather out as well, as there is quite a bit gunk behind the breather I am having trouble cleaning out.
---------- Post added at 12:12:02 PM ---------- Previous post was at 12:09:45 PM ----------
Man, I wish there was an edit button available for posts...
also, anyone have any trick for cleaning between the head fins?
The Following User Says Thank You to CycleKartBow For This Post:
  #33
Old 09-06-2016, 03:23:17 PM
Finally got a chance to get back on this project today.
-New gasket for the valve cover plate cut and installed
-Currently cutting the new gasket for the Magneto Plate.
I want to get the Mag Plate back on today and pretty much get it up to the Carb/Intake and Fuel Tank referb.
I have decided not to paint it, I think for now I'm just going to clean it up and leave it Au naturel ....
I still need to figure out the trick to separating the Carb from the Air cleaner tube... it doesn't want to move...
Old 09-06-2016, 07:30:41 PM
So far so good....
Magneto plate gasket cut and plate installed, points cleaned and set, hi-tension lead cleaned up as well...
Fly wheel cleaned up and partially installed. I need to clean up the starter cup before I install it.
Need to find a replacement B-7 sparkplug, as that is what was in it.... And still figure out the carb and intake being stuck together...
ID:	262167   Click image for larger version
Old 09-06-2016, 07:38:51 PM
"Man, I wish there was an edit button available for posts..."
There is if you are a subscriber! Well not a button but you can edit your posts.
Bill
Old 09-06-2016, 08:07:58 PM
Thanks, that explains it!
Old 09-07-2016, 12:38:13 AM
Carb and air tube separated!
That took some elbow grease... Now to clean those up.
And, the spark is pretty healthy, even with the very far gone Autolite B-7 plug it came with.....must be I set the points up correctly!
Old 09-08-2016, 09:36:18 AM
Arlie Levy Arlie Levy is offline
The B has 1" exhaust and the A has 3/4" exhaust. Very easy way to identify.
Old 09-08-2016, 09:51:23 AM
The model A does not have a removable side cover on the PTO side and the model B does have a removable side cover on the PTO side.
Old 09-10-2016, 01:06:46 AM
Interesting, Thanks.
This one is not removable on the PT side and has a 3/4" exhaust Port.
I didn't get much time to work on it this evening, but I cut a new gasket to replace the one in the carb that looked like dried up shoe leather...
Tomorrow I plain to get the needle valves in and Emulsion tube reinstalled, and put the carb back on.
Briggs&Stratton BR6 project GregChauvin Small Air Cooled Gasoline Engines 7 11-04-2014 02:59:50 AM
Briggs & Stratton 1972 10hp: My first project TekNik Small Air Cooled Gasoline Engines 22 11-04-2013 03:11:17 PM
Briggs and Stratton FH Project Challenge... Here we go... Jack H Small Air Cooled Gasoline Engines 12 07-14-2012 11:34:44 PM
First Briggs&Stratton Restoration Project Updates Hit and Miss kid Small Air Cooled Gasoline Engines 7 02-13-2008 05:50:23 PM
New here, Briggs & Stratton restoration project red_metallic Small Air Cooled Gasoline Engines 14 09-25-2006 02:47:26 PM
