Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Drag Saw Collectors
Drag Saw Collectors Water cooled drag saws; Hercules, Ottawa, Wade, Vaughan, Witte, Timberwolf and Multnomah
Drag Saw Collectors
Ottawa Hit/Miss Saw Questions
this thread has 1 replies and has been viewed 1209 times
Old 03-20-2017, 08:48:10 PM
Weezer Weezer is offline
Default Ottawa Hit/Miss Saw Questions
Greetings fellow saw addicts!
I just bought a hit & miss Ottawa saw from a friend, It was buried in a barn for many, many years. I don't know what the board "kick stand" was for. One of the handles is bad, so I'm replacing everything. The winch pieces, blade support and spikes off of one of my other saws are at Cattail right now to be used for patterns for new ones. Question one, isn't the fuel tank supposed to be mounted to the head? If so, does anyone have the measurement of an original (pictures would be a big help!). I also don't quite understand the mixer. Is there supposed to be a larger leather or fiber disk behind the needle where the washer is in the picture or is that all there is to it? There was a check ball in the elbow, but I wouldn't think you would need one with the fuel above the mixer. Thanks for any advice. Jim
ID:	278039   Click image for larger version
ID:	278040   Click image for larger version
ID:	278041   Click image for larger version
The Following User Says Thank You to Weezer For This Post:
Old 03-21-2017, 10:15:58 AM
AKMark AKMark is offline
Default Re: Ottawa Hit/Miss Saw Questions
Weezer
Yes the fuel tank should be mounted on the head, as for the kickstand, its probably because the tank is low and its the only way to get it to run. Or it might be just for display. You have an ES model, I sold the one I had and don't have any pictures. As for the mixer sorry I just don't remember
The Following User Says Thank You to AKMark For This Post:
Ottawa 3hp hit & miss courtnhayd Antique Gas Engine Discussion 3 08-02-2012 09:06:14 PM
7 HP Ottawa Hit & Miss Matt Montague Antique Gas Engine Discussion 13 03-10-2012 08:31:31 PM
Ottawa Hit & Miss Help Charlie 135 Antique Gas Engine Discussion 9 09-11-2011 09:07:50 PM
5 HP Ottawa Hit and Miss M.Smith Antique Engine Archives 3 07-09-2003 09:27:29 PM
Ottawa 2HP (hit & miss gov.) Ed Antique Engine Archives 2 05-01-2002 09:02:48 PM
