Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Drag Saw Collectors
Drag Saw Collectors Water cooled drag saws; Hercules, Ottawa, Wade, Vaughan, Witte, Timberwolf and Multnomah
Drag Saw Collectors
Ottawa TE Valve
this thread has 2 replies and has been viewed 1087 times
Old 05-07-2017, 01:44:35 PM
blacktinlizzie blacktinlizzie is offline
Default Ottawa TE Valve
Just a question on the two piece exhaust valve on this engine.
How is the head secured to the shaft mine the valve head is slightly out of line and seems to be attached with hard solder can this be aligned and heated to make it seat?
Old 05-07-2017, 04:24:52 PM
AKMark AKMark is offline
Default Re: Ottawa TE Valve
They are threaded in the valve head, I think mine are 1 piece but it's been awhile since I had it apart. Unless you cannot get it to seat I would just use it the way it is.
Old 07-03-2017, 02:15:16 PM
IronworkerFXR IronworkerFXR is offline
Images: 49
https://www.smokstak.com/forum/pictu...pictureid=5991
---------- Post added at 02:15:16 PM ---------- Previous post was at 02:09:43 PM ----------
https://www.smokstak.com/gallery/fil...-37-32_277.jpg
Mine fell off the valve stem , I reamed the hole true, then turned the stem to a step, then put on valve head and put in collet and vise , then heated the stem end and peened over while red hot ,, dont over do it . works great and looks like that was how the factory did them.
JC
The Following User Says Thank You to IronworkerFXR For This Post:
Ottawa 2hp model BS needle valve deercreekbrent Antique Gas Engine Discussion 0 10-23-2015 08:29:07 PM
valve guide to valve stem clearance Steve V. Machine Shop and Tool Talk 13 10-22-2014 06:55:59 PM
Diamond valve / needle valve. HVFD FireFighter Oil Field Engines & Related Equipment 5 10-01-2009 04:49:58 PM
Ottawa exhaust valve timing, decal & age question. JKKD Antique Gas Engine Discussion 3 02-16-2009 09:27:00 PM
OTTAWA, engine and tractor show in ottawa kansas veedol_al1 Antique Engine Archives 0 09-19-2004 08:16:45 PM
