Briggs 446777 Engine, Low Oil Shut Off
this thread has 33 replies and has been viewed 2121 times
Old 10-17-2017, 09:22:06 AM
Default Re: Briggs 446777 Engine, Low Oil Shut Off
about 150 ft. I mow it in both directions so the machine is running both ways at a angle.
I mowed a half acre yesterday and it used some oil.But there was NO smoke,no leaks. Strange.
If it uses oil I will just check it each use I guess. If the rings weren't seated I can understand some usage.
Old 10-17-2017, 08:39:06 PM
gdstew gdstew is offline
It will use a little oil every time until it warms up to operating temperature. That aluminum really expands! Check the oil every time you start it up!
Old 12-07-2017, 07:13:15 PM
Well It had about 3.5 hours on it so i changed break in oil today just so I would know it was done and not forget about it. I must say,the engine seems to have more power than it ever did.Plows right thru leaves and stuff that last year it would bog down and I would have slow down.
Old 11-24-2018, 10:11:51 PM
All summer this machine has given little problems at all until a couple weeks ago.It is hard to start as in does not want to turn over easy even with a jumpstart, and seems to be missing on 1 cylinder.it runs on it but not as well as the other.. I wound up taking something else and later that day it fired right up when it was warmer.
Will the straight 30 wieght oil affect starting in cold weather that noticably?
I am thinking of replacing plugs first for the skip and then check valve clearances,if that aint the problem,then the coils.
Onan 4.0BGE 4000 Gen Sat.Stops running after motorhome engine is shut off. suebratton Onan Generators 28 02-10-2015 02:28:40 PM
Engine wont shut off DaveHC Garden Tractors / Mowers / Scooters 2 02-19-2012 04:36:17 PM
Kohler 7.5c62 generator ENGINE making noise during shut down mobus1 Kohler Generators 7 06-29-2010 08:00:12 PM
What is the proper way to shut off a hit-and-miss engine? andy b. Antique Gas Engine Discussion 14 05-07-2009 10:07:45 PM
