Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Drag Saw Collectors
Drag Saw Collectors Water cooled drag saws; Hercules, Ottawa, Wade, Vaughan, Witte, Timberwolf and Multnomah
Drag Saw Collectors
Drag Saw, Vaughn, Model L Breaker Points
this thread has 8 replies and has been viewed 965 times
Old 07-28-2018, 11:16:04 PM
chashlow chashlow is offline
Default Drag Saw, Vaughn, Model L Breaker Points
The breaker points on the end of the crankshaft make and break (VOM reading), but the resistance is apparently too high to consistently fire the batt/coil/plug system. Before I tear into it to clean it up, please describe the hardware and what to look out for. And what is with the one wire terminal that seems to be "floating"? Engine hasn't been run in recent times--ignition system parts missing. But we've built one up with a T-Model coil and batt and just need the points to work well to try to start the engine. Also, How should we set up the carb mixture to start it? Any advice is welcome. Thanks
Old 07-31-2018, 11:27:00 AM
Chris J Chris J is offline
Images: 833
Default Re: Drag Saw, Vaughn, Model L Breaker Points
Can you post some pictures? Also, serial number and model. There are a few different styles.
Old 08-02-2018, 01:56:41 PM
Hi Chris--Don't know S/N. Here's pics.[IMG]img_20180617_160931_burst_02[/IMG] and IMG_20180617_160931_burst_01. Thanks. chl
Old 08-11-2018, 03:23:19 PM
Images: 833
No pictures...
Old 08-18-2018, 07:58:16 PM
Hi Chris J--I finally got info. It is SN 52540 and Model L. Here's pics. I need help. Thanks. chashlow
ID:	316568   Click image for larger version
Old 08-18-2018, 10:30:10 PM
Images: 833
Sent you a private message chashlow, I have some paperwork that will help you.
Old 08-19-2018, 04:59:14 PM
Hi Chris J. I already answered, but found another pic to post on my Vaughn. chashSN and Model1.pdf
I hope this comes through.
Old 10-23-2018, 10:57:19 PM
Thanks, again, Chris. Got it running!! New question---Can you tell me if I can solder to the 3 terminals on a T-Model coil without damaging the coil. I want to adapt the coil for use on the Vaughan and wire it direct to the other components. Thanks. charlie
Old 10-24-2018, 10:45:46 AM
Images: 833
Yes, A lot of people solder clips onto the terminals so it is easier to connect and remove the wires. Or you could solder the wires and "hardwire" it.
The Following User Says Thank You to Chris J For This Post:
Vaughn 4 stroke drag saw Tom Street Drag Saw Collectors 1 02-22-2017 05:55:57 PM
Vaughn Drag Saw Larry K Drag Saw Collectors 6 09-18-2010 11:42:18 PM
Need Mag for Vaughn drag saw Walt Roys Magnetos, Ignition Coils and Spark Plugs 2 11-09-2009 09:13:21 AM
Vaughn Drag Saw BobRR Antique Gas Engine Discussion 7 11-30-2005 04:09:10 PM
Vaughn Drag Saw Luke Kissell Antique Engine Archives 0 03-02-2003 08:09:51 AM
