Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Drag Saw Collectors
Drag Saw Collectors Water cooled drag saws; Hercules, Ottawa, Wade, Vaughan, Witte, Timberwolf and Multnomah
Drag Saw Collectors
Witte Drag Saw Pieces
this thread has 2 replies and has been viewed 400 times
Old 08-01-2018, 07:52:36 AM
primerk5 primerk5 is offline
Default Witte Drag Saw Pieces
I recently picked up a Witte B Drag saw engine with what appears to be an earlier headless Witte Drag saw Cart. How they ended up together is beyond me, but the engine doesn't fit the bolt hole locations in the cart so they definitely aren't for one another.
I'm missing most of the clutch assembly, and the only piece I have I think may be for the headless version. It appears the Clutch used on the later B engines are different.
How long should the shaft be for the engine where the clutch would go. Looking at pictures of other drag saw engines, it looks like the shaft where the clutch would be should be twice as long as what I have. Mine doesn't appear to be cut off but i'm not sure.
I'm going to attach a picture of it so that you can see what I have. The engine is just sitting on the cart so I could see if I could make it work. I was thinking if I could get a Clutch for it I may put it together even though it doesn't go together.
Probably has been a very long time since the engine ran but it basically fired right up after some clean up and lubrication.
The Following User Says Thank You to primerk5 For This Post:
Old 08-01-2018, 01:18:41 PM
Weezer Weezer is offline
Default Re: Witte Drag Saw Pieces
Mine is 2.5" past the face of the gear. That's where the "throw out bearing" rides.
Old 08-01-2018, 01:53:48 PM
ok, that settles that. There isn't any shaft sticking out with the gear thing I have in place.
3hp Witte Drag Saw JohnDeere80 Antique Gas Engine Discussion 17 08-21-2018 10:53:50 PM
Witte Drag saw Donnie Hargreaves Drag Saw Collectors 12 01-10-2012 10:33:34 PM
correct mag for witte drag saw ? Dale Freidline Drag Saw Collectors 6 06-22-2011 11:28:35 PM
Witte Drag Saw Donnie Hargreaves Antique Gas Engine Discussion 7 07-15-2010 08:36:02 PM
Looking for info on my Witte Drag Saw Steve Harris Antique Gas Engine Discussion 7 08-24-2007 01:24:41 PM
