Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Drag Saw Collectors
Drag Saw Collectors Water cooled drag saws; Hercules, Ottawa, Wade, Vaughan, Witte, Timberwolf and Multnomah
Drag Saw Collectors
Ottawa 2 Flywheel Slip Clutch Material Help
this thread has 1 replies and has been viewed 240 times
Old 09-29-2018, 06:06:21 PM
AndrewWV AndrewWV is offline
Default Ottawa 2 Flywheel Slip Clutch Material Help
i have a ottawa 2 hp, 2 flywheel log saw, and it has the spring tensioned slip clutch. Any idea on what i should use as the clutch material between the surfaces of the flywheel and the surface of the gear hub? The manual i have calls it a "clutch fiber washer", but thats all it says about it.
Thanks for your help
ID:	319843   Click image for larger version
Old 09-30-2018, 04:11:07 AM
Ray Cardoza's Avatar
Default Re: Ottawa 2 Flywheel Slip Clutch Material Help
try mcastercarr for the clutch liner material. that would probably work just fine
Clutch shoe material? JBoogie Steam Stationary Engines, Traction Engines, Steam Boats 8 07-09-2010 07:46:51 AM
Slip Ring Material K D Redd Onan Generators 3 01-08-2010 10:33:02 AM
Friction material for clutch on 3-5 LA JHFoster Antique Gas Engine Discussion 4 05-01-2009 10:10:16 PM
Lawnmower Clutch Material MowerFan Garden Tractors / Mowers / Scooters 5 07-28-2007 05:47:19 PM
clutch material ?? Steamrguy Antique Gas Engine Discussion 3 12-29-2005 02:07:28 AM
