Reproduction Efforts on Protecto-Motor Air Cleaners
this thread has 5 replies and has been viewed 454 times
Old 11-11-2018, 11:48:02 AM
Tom Schaech Tom Schaech is offline
Default Reproduction Efforts on Protecto-Motor Air Cleaners
I thought I'd post this topic again to see if anyone out there had given any serious thought to the classic "louvered" aluminum air cleaners as found on Briggs alphabetical series engines, and later, on Homelite MEPs for the military. Manufactured under the name "Protecto-Motor" (I believe a subsidiary of Donaldson); I think there's a market for them. The challenge, as many have correctly pointed out, is to fabricate a punch or other device to uniformly stamp the louvers around the "soda can". I actually contacted Donaldson a while back to see if they would at least look to see if the old manufacturing equipment was there; never really got a solid answer.
What made me revisit this is I see a Japanese outfit is making a much different air cleaner for minibikes and motorcycles, but utilize the louvers on the cover. Anyone have any thoughts on this? I don't see a way of accurate reproduction doing by hand-you'd never get the correct uniformity, and certainly too time-consuming along those lines for any attempt at mass production.
Thought this would be a good thread and imagination stoker now that the cruel, mean, non engine show winter season is fast approaching!!!!
The Following 4 Users Say Thank You to Tom Schaech For This Post:
Old 11-11-2018, 12:32:10 PM
Junkologist's Avatar
Images: 160
Default Re: Reproduction Efforts on Protecto-Motor Air Cleaners
Iíve found the cast aluminum elbows that the air cleaners sit on much harder to find than the air cleaners themselves. I wish someone would repop those, especially the ones for the WA and R models.
Mike
SmokStak member #146
Old 11-11-2018, 01:26:27 PM
Motormowers's Avatar
The cast parts should be easy. Maybe look into madeinchina.com or alibaba.com for a company in China to make them. The tooling would be too expensive here. I looked into having the Tillotson MS5A carbs recast years ago by Newton/New Haven die casting which was one of three companies I know of that used the same tooling to cast them for Tillotson and it was about $10k just to retool. Not worth it.
Remove the all rotten apples out of your basket of life and toss them in the trash where they belong.
The Following User Says Thank You to Motormowers For This Post:
Old 11-11-2018, 06:24:46 PM
G.M.Johnson G.M.Johnson is offline
I kicked this around as well, I even started to work up a set of dies to punch the louvers. But as always got too many more important things to get done. I would think making repop cast aluminum elbows should be pretty easy but from the looks of things not so. Or maybe use one of them 3D printers some how. It wouldn't be made of aluminum but that would better then nothing. Just some thoughts.
Old 11-12-2018, 09:31:24 AM
There's a foundry in southern PA that can do the casting for the elbows. Not terribly expensive, and they do good work. I really want to continue exploring the "can" repro as I know many folks would benefit from their availability. Looking for others to join the discussion and provide helpful input, please!!!
Old 11-13-2018, 01:25:44 AM
If you can get the cylinders made cheaply I still think the best way to make the louvers is to roll them like a HVAC beading tool works on ducting tubes. Have two rollers one male one female and roll them on.
Rumely air cleaners Edwin Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 05-11-2008 09:46:18 PM
Centrifugal oil cleaners Robt. Antique Gas Engine Discussion 4 03-01-2007 02:48:25 AM
early air cleaners Tore Blom Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 02-28-2006 07:34:33 PM
Ultrasonic cleaners leonard keifer Antique Engine Archives 4 02-15-2004 05:26:04 AM
Parts Cleaners Norm Antique Engine Archives 11 01-13-2002 11:51:12 PM
