Vintage Generator with a Power Products AH47 carb issue
this thread has 17 replies and has been viewed 1262 times
Old 11-20-2018, 04:52:31 PM
Pakmaine Pakmaine is offline
Default Re: Vintage Generator with a Power Products AH47
Hi Chris thank you for that information. What is the flywheel / recoil hold down?
---------- Post added at 03:49:54 PM ---------- Previous post was at 03:41:45 PM ----------
Hi Arlie
Thanks for getting back to me. I had a hard time because I was looking for a Fairbanks Morse motor, because thatís whatís written on the recoil cover. But the yellow decal I ran across and search that decal and it was on a AH47 Power Products motor. The recoil took a lot of work to get it freed up from being froze, and I didnít know any better and kept putting penetrating oil on it to try and get it to turn. Thatís when I found this site and I read someoneís thread about the recoil works great, actually better with no oil or WD40. I am going to look for that tag that Chris was telling me about. Again, thank you.
---------- Post added at 03:52:31 PM ---------- Previous post was at 03:49:54 PM ----------
There is another thing I donít know what it is on the carburetor and itís a dial, with the numbers 0 thru 9. What is that for?
Old 11-20-2018, 06:58:09 PM
Does anyone know where I could get a copy of the original owners manual for this old motor? I have an old Martin 60 outboard motor and I got a copy of the original manual for it. I printed it
So if anyone knows where I can download any info on the Power Products model 1000 AH47 pleas let me know ... thanks again
Old 11-20-2018, 09:47:18 PM
Ogrebeast64 Ogrebeast64 is offline
Lightbulb Re: Vintage Generator with a Power Products AH47
HERE is what I've found about replacing the carby on it, and that's about all I could find so far.
Old 11-21-2018, 12:04:22 AM
GADavis GADavis is offline
The dial with the numbers on it is actually your load jet or high speed jet as some refer to it. Adjust this under a load so it just begins to sound like a 2 stroke. Without a load it should sound like a 4 stroke or blubbering. A lot of these engines were just a plain aluminium rod bearing or at best a bronze bushing in the rod and lots of times the crankshaft bearings were just plain aluminum bores or bushings. Some of the later high end engines had needle bearings. Be sure your crankshaft seals are good or it will be hard to crank and also hard to adjust the carburetor mixture.
Last edited by GADavis; 11-21-2018 at 12:13:16 AM. Reason: needed to add information.
The Following User Says Thank You to GADavis For This Post:
Old 11-21-2018, 01:13:56 AM
K-Tron K-Tron is offline
Power Products lists the MT37A as part number 630137. You need a Tecumseh/PP 630428 repair kit and a Tecumseh/PP 630258 gasket kit. Tillotson will list their own part numbers for the MT carburetors. These numbers are from my PP book. Tillotson lists the MT37 as being in production from 1953 until 1962.
Chris
Old 11-21-2018, 09:30:32 AM
Wow..... thank you so much for that valuable information. I really appreciate it. I did fire it up and it runs like a clock. I would love to post it as it is only 19 seconds but for some reason it won’t post.
---------- Post added at 08:30:32 AM ---------- Previous post was at 08:11:53 AM ----------
I got it running last night and it ran smooth. I was so happy all I had to plug into it was a fan and it worked Awesome. Iím thinking someone used this motor generator in a barn to run lights or some farm tool. I have a short video of it running last night and itís only 19 seconds long, but I canít post it... I tried to post it a couple times but was unsuccessfull Thanks for your help
Old 11-21-2018, 02:39:25 PM
Vanman Vanman is offline
Default Re: Vintage Generator with a Power Products AH47 carb issue
You'll have to upload your video to a host site such as YouTube, then copy and paste the link into a post here.
Old 01-17-2019, 09:10:14 PM
Thank you
http:/youtu.be/-U1kyJloFjk
If you go here you will see I got the old AH 47 model 1000 running smooth and producing power.... This was a very fun project.... thank you all for your help
---------- Post added at 08:02:43 PM ---------- Previous post was at 07:40:59 PM ----------
Well I hope this works. If so youíll see I got this running smooth and generating power. Sweet
---------- Post added at 08:10:14 PM ---------- Previous post was at 08:02:43 PM ----------
The Following User Says Thank You to Pakmaine For This Post:
Power Products AH47 - All Finished and Test Run! Kammer0072000 Small Air Cooled Gasoline Engines 10 11-21-2018 09:32:20 AM
Power Products AH47 decals desotonut1953 Small Air Cooled Gasoline Engines 3 11-21-2018 09:21:31 AM
Power Products Ah47 2 Stroke Flywheel richardkb Small Air Cooled Gasoline Engines 0 03-07-2017 04:54:55 PM
Power Products AH47 help thambach Small Air Cooled Gasoline Engines 22 12-29-2013 08:42:00 PM
Power Products AH47 - How to time it?? Kammer0072000 Small Air Cooled Gasoline Engines 4 03-27-2009 10:25:51 PM
