Briggs Model Y No Spark
this thread has 5 replies and has been viewed 391 times
Old 11-23-2018, 08:53:53 AM
Cnew Cnew is offline
Default Briggs Model Y No Spark
Looking for some expertise on a Briggs model Y. Going through the engine yesterday and unfortunately no spark. I puller the flywheel and sanded the contacts and cleaned up the magnets. The magneto looks good visually. Is there anything else I can do to trouble shoot this? Is there a simple way to test the magneto coil and condenser?
Old 11-23-2018, 09:01:05 AM
BHoward BHoward is offline
Default Re: Briggs Model Y No Spark
Recheck the points. There could be a grane of sand between them.
Old 11-23-2018, 10:13:22 AM
Junkologist's Avatar
Images: 160
Take a business card and slide it in between the points, but donít pull the card out without first lifting the points open, otherwise paper fibers will be caught between them.
Mike
SmokStak member #146
Old 11-23-2018, 01:43:46 PM
Tom G Tom G is offline
I'd try replacing the condenser.
Old 11-23-2018, 11:21:01 PM
Brian Lynch's Avatar
Images: 23
Take a look here. you will find a manual for the Model Y engine https://www.briggsandstratton.com/na...fications.html
The Following User Says Thank You to Brian Lynch For This Post:
Old 11-24-2018, 10:51:44 PM
Mike in NC's Avatar
Images: 74
Here is a link to our page with Briggs Manuals.
Briggs & Stratton Manuals
SmokStak Member #28
The Following User Says Thank You to Mike in NC For This Post:
Recommended Briggs Model Y Spark Plug Cnew Small Air Cooled Gasoline Engines 1 11-18-2018 10:49:34 AM
Briggs and Stratton Model A Spark Plug? CycleKartBow Small Air Cooled Gasoline Engines 6 09-15-2016 01:55:37 PM
Briggs & Stratton model 23 spark advance 54hawken Magnetos, Ignition Coils and Spark Plugs 2 01-11-2015 11:45:22 PM
Briggs Model B Weak Spark - Help alcor1017 Magnetos, Ignition Coils and Spark Plugs 2 06-24-2010 12:48:41 AM
Spark Plug For Briggs Model ZZ Trashman Small Air Cooled Gasoline Engines 7 12-22-2007 04:42:39 PM
