Help Needed to identify Briggs Gas Tanks
this thread has 4 replies and has been viewed 298 times
Old 12-14-2018, 12:07:39 PM
Firewoodguy's Avatar
Firewoodguy Firewoodguy is offline
Default Help Needed to identify Briggs Gas Tanks
I have a couple gas tanks I believe from old briggs engines. can someone tell me what model these would be found on? 2 on the right side are identical. Thank you
Old 12-14-2018, 12:55:00 PM
Junkologist's Avatar
Images: 160
Default Re: help needed to identify Briggs gas tanks
The two on the right are typically found with Y or L models. The other tank looks like the type that would be found on an FHI, an H, or a T model.
Mike
SmokStak member #146
Old 12-14-2018, 12:55:23 PM
Pat Barrett Pat Barrett is online now
Default Re: Help Needed to identify Briggs Gas Tanks
The two on the right appear to be possible aftermarket tanks for the Y, possibly also on the W series or other, the one on the left looks like tanks that are on like the 8, 14, and 23 series engines. For sale?
The Following User Says Thank You to Pat Barrett For This Post:
Old 12-14-2018, 12:59:34 PM
turbo's Avatar
turbo turbo is offline
The two on the right would have been attached to a washing machine and will work with several models including: Y, WM, WMB, L, LI, LA. I don't recognize the one on the left.
The Following User Says Thank You to turbo For This Post:
Old 12-14-2018, 01:28:41 PM
grega's Avatar
grega grega is offline
Images: 106
Iíd be interested in the one on the left with the outlet on the bottom if you decide to sell it. Itís for an H or FHI.
-Greg
"There only origionial once"
The Following User Says Thank You to grega For This Post:
Help Identify Briggs? Firewoodguy Small Air Cooled Gasoline Engines 2 11-28-2017 09:27:41 PM
Briggs & Stratton reproduction gas tanks Bigjoedo Small Air Cooled Gasoline Engines 13 10-10-2015 01:11:52 AM
Briggs & Stratton WI gas tanks Bigjoedo Small Air Cooled Gasoline Engines 0 08-16-2011 08:12:25 PM
Trying to identify 8 hp briggs Ricky Harris Garden Tractors / Mowers / Scooters 1 05-17-2009 10:54:51 AM
Need Help. Trying to identify Briggs. Brett Small Air Cooled Gasoline Engines 6 01-10-2008 06:28:01 PM
