Briggs & Stratton ybsxs.5012vp manual?
this thread has 11 replies and has been viewed 289 times
Old 01-04-2019, 12:42:49 AM
gdstew gdstew is offline
Default Re: Briggs & Stratton ybsxs.5012vp manual?
just being practical. You can get a whole running mower, cheaper and easier than trying to patch up what you have. Everything that was any good has been stripped off.
And, no I did not accept Murray mowers for repair in my shop, there was no end to fixing them. Typical problem was belt/blade work. The spindle assy was shot, the deck was rusted through where the spindle bolted on. The Idler pulleys were shot, the bracket that held the pulley bent, the lever that engaged the bracket was worn out, etc, etc. And sorry, I can't put your NAPA belt on it and guarantee my work. You have to know when to walk away.
Old 01-04-2019, 01:56:11 AM
I understand, I was actually thinking of having it hauled off for scrap. Although the frame intrigues me as a base for a 10 2.5 inch gauge locomotive build. Stripped down without all the mower crap attached it would be a base for building a shunter like this one. https://www.trovestar.com/images/Col..._124214_19.jpg
6HP Honda clone and a old Alt running two 24v winch motors as traction motors. Simply electrical system similar to http://www.smex.net.au/reference/Alt...Traction02.php
Find a cheap source for flat steel about 1/4 thick press it into some 2x2 ties and have a crude RR. Crude track of similar design seems to handle a Bigboy just fine in New Zealand. https://www.youtube.com/watch?v=C48pU2_KePg
Robert
Briggs & Stratton “FH” instructions & Parts Manual TractorDom Small Air Cooled Gasoline Engines 0 11-28-2015 06:42:41 PM
Briggs and Stratton Model PB manual oldatlas10 Small Air Cooled Gasoline Engines 1 03-22-2014 08:16:20 PM
Old Briggs & Stratton need parts and manual for DAI Small Air Cooled Gasoline Engines 8 02-25-2014 12:25:35 AM
Need Briggs & Stratton owners manual 270373 CaseHead Antique Gas Engine Discussion 5 02-14-2010 04:44:13 PM
Briggs & Stratton Tune-Up Manual Mike in NC Small Air Cooled Gasoline Engines 0 03-18-2007 08:18:20 PM
