Power Products AH47 - All Finished and Test Run!
this thread has 10 replies and has been viewed 2112 times
Old 04-03-2009, 08:16:48 PM
Kammer0072000 Kammer0072000 is offline
Default Power Products AH47 - All Finished and Test Run!
One of the easiest little engines I've ever rebuilt. Never did find crank case seals but she runs like a top. Loud as heck but I can't find a muffler either??? Bit of a pattern here. Oh well, here she is...
Name:	Power Products.jpg
ID:	51563   Click image for larger version
Name:	Power Products (1).jpg
ID:	51564   Click image for larger version
Name:	Power Products (2).jpg
The Following 2 Users Say Thank You to Kammer0072000 For This Post:
Old 04-03-2009, 09:05:16 PM
kelby kelby is offline
Thumbs up Re: Power Products AH47 - All Finished and Test Run!
Very nice restoration! Thanks for sharing.
The Following User Says Thank You to kelby For This Post:
Old 04-03-2009, 09:30:27 PM
Exclamation Re: Power Products AH47 - All Finished and Test Run!
Please advise on the center to center measurement of the exhaust mounting holes, and the width and breadth of the exhaust port. I may have a muffler for the engine.
Old 04-03-2009, 10:39:21 PM
Default Re: Power Products AH47 - All Finished and Test Run!
A muffler would be GREAT!!!
2 1/8" center to center bolt pattern
Exhaust Port 1 11/16" x 11/16"
Many many thanks!
Old 04-03-2009, 10:43:42 PM
CubCadet107 CubCadet107 is offline
Looks like a Tecumseh SnowKing muffler would bolt up to that, I will try to find a part number for you.
-Jordan
The Following User Says Thank You to CubCadet107 For This Post:
Old 04-04-2009, 01:17:48 AM
I have several types of power products mufflers, I will check on them tomorrow.
Old 04-04-2009, 02:07:28 AM
BWegher BWegher is offline
Shows the muffler on my AH47. The bolts are 2 inches long. You are also missing the sheet metal over the fins.
The Following User Says Thank You to BWegher For This Post:
Old 04-04-2009, 11:07:59 AM
Mac Leod Mac Leod is offline
Hey, Very nice Power products engine, it came out well. seems to me that most two stroke engines are missing there mufflers, do not know why but better than half of them that I have picked up <mostly power products> are missing there mufflers.
good job
The Following User Says Thank You to Mac Leod For This Post:
Old 04-04-2009, 11:20:46 AM
One more thing, it slipped my mind but my buddy does have the seals in stock, send me an email and ill see what I can come up with
Old 04-04-2009, 11:23:40 AM
And so long as we are at it, it seems you are missing the rubber boot that seals dust out of your governor housing? Goes around the shaft?
Power Products AH47 Question - Splitting the crank case? Kammer0072000 Small Air Cooled Gasoline Engines 7 11-29-2009 08:36:57 PM
Power Products AH47 - How to time it?? Kammer0072000 Small Air Cooled Gasoline Engines 4 03-27-2009 10:25:51 PM
Just finished resto of new engine to collection-Power products Mac Leod Small Air Cooled Gasoline Engines 3 03-22-2009 10:59:08 AM
Power products John Rolli Small Air Cooled Gasoline Engines 8 12-25-2007 09:57:47 PM
Power Products engine memjim Antique Gas Engine Discussion 1 08-06-2006 12:13:09 PM
