Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Drag Saw Collectors
Drag Saw Collectors Water cooled drag saws; Hercules, Ottawa, Wade, Vaughan, Witte, Timberwolf and Multnomah
Drag Saw Collectors
Stover Dragsaw Clutch
this thread has 6 replies and has been viewed 1938 times
Old 05-18-2010, 09:42:20 PM
wydiver wydiver is offline
Default Stover Dragsaw Clutch
I just got a stover dragsaw and was thinking that the clutch is missing some parts. Does anyone have a picture of this clutch and could you post please? this is the only picture I have right now. I have the clutch removed and will post pictures tomarrow of the indivual pieces.
Thanks for all the help.
Bryon
Old 05-19-2010, 06:52:01 AM
Tom Martin Tom Martin is offline
Email Not Working
Default Re: Stover dragsaw clutch
Wendel's "Power in the Past" Vol.3 has a couple of pictures of Stover drag saws. From those pictures, it appears that you are only missing the clutch hand wheel.
The Following User Says Thank You to Tom Martin For This Post:
Old 05-19-2010, 06:56:56 AM
Doug Kimball's Avatar
Images: 78
See this thread for a drag saw brochure:
http://www.smokstak.com/forum/showthread.php?t=59864
In Kennebunk, Maine;
Doug Kimball
The Following User Says Thank You to Doug Kimball For This Post:
Old 05-19-2010, 09:10:46 AM
Here are some more pictures...I also believe that the handwheel is missing but still cannot get my head around how in ingages. thanks again for all the help.
Bryon
Old 06-02-2010, 10:06:00 PM
jawgroth jawgroth is offline
As you pull out on the hand wheel, the tapered collar that the handwheel is attched to slides on the shaft. The two fingers ride on this taper and pivot out, pushing in the 2 pins. the 2 pins push on the friction plate which engages the sprocket. Hope that helps. I have a picture of my disassembled clutch in the dragsaw group.
Eric.
Old 12-19-2017, 07:25:04 PM
Jack Finzel Jack Finzel is offline
Bryon
Attachment 79315
Did you ever find anything on this? I am restoring a 1922 patent model and trying to find the friction portion of the clutch. I have the handle and clutching mechanism. There are two steel pens that are levered into something that was probably a disk. Trying to find a picture so I can replicate. Thanks.
Old 01-21-2018, 04:01:32 PM
Thanks, I have the book but it doesn't show the clamping mechanism (hooks or whatever) up front.
---------- Post added at 02:59:44 PM ---------- Previous post was at 02:56:22 PM ----------
According to Wendel's they didn't start making them until 1924.
The clutch is just metal to metal as far as I can tell on both sides of clutch disks.
---------- Post added at 03:01:32 PM ---------- Previous post was at 02:59:44 PM ----------
Stover Drag Saw Clutch Cone Fabrication. OTTO-Sawyer Antique Gas Engine Discussion 10 11-10-2017 09:30:38 AM
Dragsaw ID & Value? PTraubert Drag Saw Collectors 4 07-14-2016 01:05:06 PM
Hercules Dragsaw Clutch Serious Help larry bee Drag Saw Collectors 11 01-20-2015 05:23:36 PM
Stover Clutch jawgroth Antique Gas Engine Discussion 2 10-01-2009 01:16:35 PM
dragsaw Boris Antique Engine Archives 0 10-29-2001 06:33:56 PM
