Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Drag Saw Collectors
Drag Saw Collectors Water cooled drag saws; Hercules, Ottawa, Wade, Vaughan, Witte, Timberwolf and Multnomah
Drag Saw Collectors
Vaughan Drag Saw Engine
this thread has 13 replies and has been viewed 4593 times
Old 01-19-2011, 03:16:31 AM
Turbo-T Turbo-T is offline
Default Re: Vaughan Drag Saw Engine
Aahhh. Proceeding cautiously.
Old 01-22-2011, 12:35:22 AM
Rich Fowler Rich Fowler is offline
Photo Re: Vaughan Drag Saw Engine
Dana,
Here is a cross section of the Clutch that I scanned from my manual. The clutchbolt (#5) is RH thread but the clutch band (#7) and the Flywheel nut (#9) is LH. You can remove the clutch as an assembly by removing the clutch bolt (RH) and then putting a large wrench on the Flywheel bolt (LH) spinning the whole unit off. If you must get the clutch apart you must put a spanner on (#7) and a large wrench on the Flywheel Nut (#9) and twist LH.
I had to put a lot of heat on the hub of the clutch band (#7) to get it to release from the Clutch Spindle (#9).
I had to take my clutch apart because the lining was falling off but if yours is ok then just remove it as a unit.
Rich
Old 01-22-2011, 01:04:52 AM
Dana,
(trying to resend this because picture didn't go)
Rich
The Following User Says Thank You to Rich Fowler For This Post:
Old 08-24-2016, 01:29:33 AM
WetCoastDave WetCoastDave is offline
Thank you for the drawing of the Vaughan clutch. I have the drum, band and the cone but couldn't figure out what parts were missing or where they went. Gonna have to get fabricating now.
Vaughan drag saw engine questions azmasseyguy Antique Gas Engine Discussion 0 11-28-2009 03:10:17 PM
Vaughan drag saw photos Grape Antique Gas Engine Discussion 2 08-10-2009 10:44:18 AM
Vaughan Drag Saw d gibson Farm + Industrial Antiques and Collectibles 11 09-18-2007 09:16:51 PM
my new toy - Vaughan drag saw Chris J Antique Gas Engine Discussion 8 07-09-2007 08:18:02 PM
Vaughan Drag Saw Tom R. Paur Antique Gas Engine Discussion 6 12-20-2006 02:02:25 AM
