Power Products Model 150 Engine
this thread has 6 replies and has been viewed 2332 times
Old 02-22-2011, 06:16:40 PM
Fireball1964 Fireball1964 is offline
Default Power Products Model 150 Engine
Hi,
I recently picked up this little engine at an auction and I was wondering if anyone had any info on this Power Products Model 150 engine. I am working on gathering parts to build an old motorized bike and I already own 2 AH-47 engines, but I'd like so find out the specs on this engine before I choose what engine to use. If this one has more power I'd like to use this, plus I like the looks of the cooling fins on the head more then the AH-47's.
Thanks!
ID:	101060   Click image for larger version
ID:	101061   Click image for larger version
ID:	101062   Click image for larger version
Old 02-22-2011, 11:37:35 PM
Banjo Banjo is offline
Default Re: Power Products Model 150 Engine
Sorry, no specs for you , but that is a cool lookin little 2-stroke. It'd be neat on a bike.
Old 02-23-2011, 10:45:16 AM
Exclamation Re: Power Products Model 150 Engine
Probably only puts out 1 to 11/2 HP. Looks like a neat little set up as is! What is the output of the generater? It looks like someone, at one time, mounted a Fairbanks recoil starter on the engine. It originally had a wrap a rope starter on it, as evidensed by the arrow on the housing. The fairbanks starter had a sharp pawl that dug into the interior of the aluminum starter cup that you have on your engine. it was sorta crude, but made starting the engine less of a chore, as it was with the wrap a rope type.
Old 02-23-2011, 02:57:37 PM
Ya, that was my other thought, This motor would be kind of fun to restore and leave as-is on its own stand. I think its a 24volt Generator, probably used to charge tractor batteries or something.
Old 02-23-2011, 11:00:08 PM
Larry Rarus Larry Rarus is offline
Speaking of the stand..... Is that an oil filter boss clearly evident in one of the photos? It looks like a place for an automotive type oil filter to spin on. Obviously not for this engine but whatever used that stand before.
Old 02-24-2011, 12:50:24 AM
That 'oil filter mount' is connected to the engine muffler. It may be what's left of a can type muffler, similar to those used by Coldwell and Jacobsen. They were very quiet. The stock muffler on the power products engine, is loud.
Old 11-22-2018, 12:16:13 PM
Pakmaine Pakmaine is offline
Wow looks a lot like mine
Power Products Model 1000 timing marks location? pcranston Small Air Cooled Gasoline Engines 7 07-30-2016 03:21:32 PM
Power Products Model 1000 HELP PLEASE bowpulpit Antique Gas Engine Discussion 1 01-15-2011 09:35:17 PM
Power Products Model 1000 crankshaft seals. Motormowers Small Air Cooled Gasoline Engines 0 07-04-2010 09:59:09 PM
Power Products model 200 info? Horse Power at 511 Small Air Cooled Gasoline Engines 9 11-29-2009 09:40:47 AM
Power Products Model 200 Type 256 RPM Questions JEbben Small Air Cooled Gasoline Engines 0 11-28-2009 01:28:25 AM
