Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel and Oil Stationary Engines
Vintage Diesel and Oil Stationary Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines.
McDonald two stroke
this thread has 7 replies and has been viewed 545 times
Old 07-18-2019, 08:59:43 AM
knares knares is offline
Default McDonald two stroke
Hi Guys
i am new on here
i am after information about a MaDonald engine with the number
OC448
i would like to know what model, year etc
its not mine, i am just interested in thees sort of things
if i know the model i can research it
thanks
Old 07-19-2019, 02:31:21 AM
eddie bedwell eddie bedwell is online now
Default Re: McDonald two stroke
Hi Knares,
welcome to the BB.
I do not know a lot about Mac 2 strokes but I believe that the S/No you have quoted is the S/No for the Lubricator on your engine--this from my
A. H.McDonald Industrial Pioneer Book, S/No listings in the back of said book.
http://www.oldengine.org/members/ken.../resources.htm
May be available thru Plough Book Sales here in Victoria these days--this link should get you there
http://www.ploughbooksales.com.au/
The following link is for TOMM site list of Registers
https://www.tomm.net.au/registers.php
Hope this helps,
Cheers,
Eddie B.
Old 07-19-2019, 05:08:44 AM
yes, you are rite, thats the only no i can find
The Following User Says Thank You to knares For This Post:
Old 07-19-2019, 05:15:07 AM
this is it
The Following 4 Users Say Thank You to knares For This Post:
Old 07-19-2019, 11:00:04 PM
any one know where i will find the engine number on this machine
thanks
Old 07-20-2019, 02:06:24 AM
Joshbilt Joshbilt is offline
You can find the serial number stamped on the rib at the top where the cylinder joins the crankcase
Old 07-20-2019, 11:30:48 AM
thanks, i will have a look
Old 07-25-2019, 05:20:08 PM
Darryl Darryl is offline
25 hp YD . Serial number is stamped on the machined flat that the fuel pump bolts to. It will start or end with the leters YD.
I see it hasnt been started since the paint job. If you dont know how to start it your better off starting a thread on the Smokstak downunder section.
Good engines !
SPI McDonald cobbadog Smokstak Down Under 3 05-09-2017 12:51:45 AM
McDonald M344 John Ross Smokstak Down Under 7 07-20-2012 01:44:00 AM
K,N, McDonald ( Vic,) fieldmarshall Smokstak Down Under 2 01-27-2011 09:16:15 AM
Another McDonald Ray Freeman Smokstak Down Under 6 12-18-2009 07:55:28 AM
Les McDonald smtwins Old Engine Memorials 3 04-24-2009 08:52:43 AM
