Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
Who made this engine?
this thread has 7 replies and has been viewed 851 times
Old 10-19-2019, 09:59:58 PM
Flyerboy Flyerboy is offline
Default Who made this engine?
Need help identifying this engine.
ID:	347005   Click image for larger version
Old 10-19-2019, 10:04:40 PM
tjohnson tjohnson is offline
Default Re: Who made this engine?
appears to possibly thrall, flwheel wrong as is adapted carb
The Following User Says Thank You to tjohnson For This Post:
Old 10-21-2019, 08:46:48 PM
Just checked out a bunch of thrall photos. close but this isn't one. Copper jacket is different as is the crankcase.
Old 10-22-2019, 06:40:07 AM
Doug Kimball's Avatar
Doug Kimball Doug Kimball is online now
I'm thinking this might be a Canadian Gas Power engine. These photos taken at a small show in 2007 in Limington, Maine.
Name:	DCP_2485 (Small).JPG
ID:	347238   Click image for larger version
Name:	DCP_2486 (Small).JPG
ID:	347239   Click image for larger version
Name:	DCP_2487 (Small).JPG
ID:	347240   Click image for larger version
In Kennebunk, Maine;
Doug Kimball
The Following 2 Users Say Thank You to Doug Kimball For This Post:
Old 10-22-2019, 10:46:05 PM
Nope, the cylinder on mine is separate casting from the crank case. Thanks for the reply.
Old 10-23-2019, 06:26:27 PM
John Davis's Avatar
John Davis John Davis is offline
Looks closer maybe to a waterman marine engine. Does it have a two piece bolt together aluminum crankcase? Cast iron cylinder with copper top water jacket? Need to see a photo of the opposite side of carb side. I do agree that the flywheel probably is not original but I could be wrong. It's a nice looking little marine engine.
Old 10-25-2019, 01:58:33 PM
It does look pretty close. This engine does have the aluminum crankcase, but it's 3 pieces and the engine mounts are horizontal. All the Watermans I saw the mounts were vertical. It does have the cast iron cylinder. I got this right by where you live. Do you know where I can get a cuno timer and a head fore a ZR Palmer?
Thanks for your reply. What engine shows doe they have here in FL?
Old 10-26-2019, 10:49:10 AM
John Davis's Avatar
Photo Re: Who made this engine?
Go to the show & Auction Calender section on the SmokStak menu. At the bottom right select month & year and it will show you all the shows for that period. Florida Flywheelers have 3 shows a year always the same months, Nov, Jan & Feb. Next show just a couple weeks away Nov 6,7,8,9, 2019 Fort Meade Florida. I have a Cuno timer I would part with not sure if it is the one you need. Click on my name and send me a email or go to my website my email is listed there at the bottom of main page. I'll send you pics. Looks like the mounts on your engine mount vertical. The engine mounts on the Waterman model K1 mount horizontal. I think Waterman probably produced different versions of the mounts for different applications would be my guess.
https://www.smokstak.com/forum/calen...h=11&year=2019
http://www.antiquengines.com/Detroit...Works_Menu.htm
ID:	347525   Click image for larger version
ID:	347526   Click image for larger version
ID:	347527   Click image for larger version
The Following User Says Thank You to John Davis For This Post:
Who made this engine? Dale Fye Hit & Miss Gas Engine Discussion 12 10-25-2017 09:31:03 AM
Home made heavy duty boring bar made. aametalmaster Machine Shop and Tool Talk 9 01-29-2010 08:48:22 AM
Who made is this engine? saengineman Hit & Miss Gas Engine Discussion 19 11-04-2008 10:29:31 AM
Who Made This Engine? Foos Jr Antique Marine Engines and Outboard Motors 4 03-18-2008 12:13:05 AM
Anyone know who made this engine? jager Hit & Miss Gas Engine Discussion 12 09-26-2007 09:28:53 AM
