Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
Evinrude 4 cyl. Inboard?
this thread has 8 replies and has been viewed 1357 times
Old 03-14-2017, 06:32:06 PM
disprodoug disprodoug is offline
Default Evinrude 4 cyl. Inboard?
Can anyone identify this engine? The aluminum manifold was broken and mostly missing when I received it. A four ball flanged Kingston, same as Evinrude 4 cycle outboard, was rigged onto a D Dispro that came with the Evinrude. the carb intake could'nt have gone through the crankcase.
ID:	277496   Click image for larger version
Old 03-21-2017, 02:04:37 AM
johnsonseahorse johnsonseahorse is offline
Images: 2
Default Re: Evinrude 4 cyl. Inboard?
Hi.The 4cycle evinrude out board is model AA and was mde only 1916-17 only.I would date this at as such.They were heavy and really expensive.And considered rare.My guess in my liture its 1916 model EE. 4hp .somewhere in the casting usually in cast iron there should be letters and numbers hand stamped.The serial numbers for double E is 59,00-59,056.The paint shold be a light machine grey,unless its from a fire pump then red.but the in boards should be grey color.I hope this willhelp u in some way.Im an a.o.m.c.i. collector .
Old 03-21-2017, 07:43:27 AM
Thanks for the info. One of the interesting pieces on this engine is the brass gear pump and it's mount.
Old 03-21-2017, 08:07:44 AM
PFT's Avatar
PFT PFT is offline
Images: 31
Does that gear pump have any markings as to who made it?
PT
Old 03-21-2017, 12:57:20 PM
I'm in Florida now, but when I get home I'll check and report.
Old 04-28-2017, 07:33:25 AM
I was recently told a company called Pacific Industries used these engines to power water pumps. Does anyone have information relating to this?
Old 05-06-2017, 06:54:45 PM
PT
There are no markings on the water pump but here are some photos of it.
Old 05-06-2017, 07:09:26 PM
Here are photos of water pump.
ID:	281596   Click image for larger version
ID:	281597   Click image for larger version
ID:	281598   Click image for larger version
The Following User Says Thank You to disprodoug For This Post:
Old 05-06-2017, 11:00:36 PM
JoeCB JoeCB is offline
A photo of the intake manifold, or remnants and connections to the cylinders would be helpful. You may be aware that the Evinrude Model AA "4-cycle" was a bit of a hi breed motor. Intake from the carb was through the crankcase as in a normal 2-cycle employing gas/ oil mix for lubrication. The intake to the cylinders via an manifold to atmospheric intake valves. Exhaust was by cam actuated exhaust valves as normal for a 4 - cycle.
Joe B
Evinrude Inboard – General help & advice needed. AusAnzani Antique Marine Engines and Outboard Motors 2 07-03-2016 09:35:44 PM
Antique Evinrude 5 HP inboard engine Gerald Horney Antique Gas Engine Discussion 2 12-11-2009 11:44:42 AM
Evinrude RBM, similar inboard, similar value? Philip Allen Antique Marine Engines and Outboard Motors 0 12-05-2009 02:43:58 PM
1926 Evinrude 2 cyl inboard Gerald Horney Antique Marine Engines and Outboard Motors 6 01-26-2009 05:04:16 PM
My first inboard...what did I buy? Chris Kirk Antique Marine Engines and Outboard Motors 3 01-13-2006 01:23:31 AM
