Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
Twin cylinder marine skeleton. What is it?
this thread has 7 replies and has been viewed 1647 times
Old 06-08-2017, 03:08:28 PM
B.L. Rodenkirch B.L. Rodenkirch is offline
Default Twin cylinder marine skeleton. What is it?
Found this at a junk store on the Fox river near Oshkosh no name-tag but a good donor engine with an in/out box Any ideas what it was???
ID:	283971   Click image for larger version
ID:	283972   Click image for larger version
ID:	283973   Click image for larger version
Old 06-08-2017, 03:53:09 PM
Neville Bond Neville Bond is offline
Default Re: Twin cylinder marine skeleton What is it???
It looks a little bit like a Watermota engine I had, I think some engines were made in the states called Waterman which were of a similar design
Old 06-08-2017, 05:53:57 PM
TekNik TekNik is offline
Hmm.. It looks remarkably two-stroke.
What is the bolt pattern for the jug?
TekNik
Old 06-08-2017, 06:24:39 PM
Chad Johnson Chad Johnson is offline
aluminum crankcase, 4 hole flywheel, looks to all the world like a T&M racing engine. T&M called it the model "B" (quotes theirs)
15 inch flywheel is a 10hp, 18 inch flywheel is an 18hp
with the friction clutch, probably an 18hp
if you could get me some measurements like crankshaft diameter and main bearing length I could confirm this.
I'm no expert on marine engines, but I have a catalog.
Chad
The Following User Says Thank You to Chad Johnson For This Post:
Old 06-08-2017, 08:02:41 PM
dick alcock dick alcock is offline
Sure looks like a Waterman K2 crank case to me
The Following User Says Thank You to dick alcock For This Post:
Old 06-08-2017, 09:30:49 PM
Seems like Neville is in the lead on this mystery!
Old 06-09-2017, 08:16:19 AM
This is my K2 after restoration , I bought it as a seized up lump, it turns out it wasn't seized up at all , the gap between the flywheel and the base was blocked with dead leaves and rubbish that stopped the engine turning.
The Following 5 Users Say Thank You to Neville Bond For This Post:
Old 06-09-2017, 02:28:03 PM
Richard Durgee Richard Durgee is offline
Default Re: Twin cylinder marine skeleton. What is it?
The chain behind the flywheel says Waterman !
The right front mount leg is wider than rear and has been broken off or corroded away. I believe that was the mount plate for a magneto .
This Waterman was one of the few models that had that chain driven
magneto.
Name:	Unknown twin Harrys mount.jpg
ID:	284032   Click image for larger version
The Following User Says Thank You to Richard Durgee For This Post:
Leyland 359/197 6 Cylinder Marine Engine mvlymington Vintage Diesel and Oil Engines 1 04-25-2016 04:20:15 AM
unknown twin cylinder marine,looks similar to a gray nat Antique Marine Engines and Outboard Motors 1 07-07-2012 07:15:54 AM
Caille Twin Marine Engine John Davis Antique Marine Engines and Outboard Motors 3 01-17-2012 05:14:04 PM
Marine single cylinder Ted_Cool Onan Generators 4 03-12-2010 11:23:05 PM
Twin cylinder Fairbanks marine photos wanted Dan Wiese Antique Gas Engine Discussion 2 03-15-2008 10:28:11 AM
