Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
Sterling Dolphin engine
this thread has 6 replies and has been viewed 1262 times
Old 08-06-2017, 09:11:34 PM
SteamfanMN SteamfanMN is offline
Default Sterling Dolphin engine
I was looking at a old marine engine in the corner of a shed for a project, I was unable to get a photo as it was too dark to get a decent photo. The model was a CRC or GRC? Any chance anyone knows anything about these? It was a 4 cylinder and one hefty unit. I believe it said it put out 115 or so hp at 1550 RPM. Any info would be appreciated as regular internet searches aren't turning up many things
Old 08-06-2017, 11:44:22 PM
clnr94 clnr94 is offline
Default Re: Sterling Dolphin engine
I have 2 Sterling engines an 8 cylinder Viking an 4 cylinder Dolphin both run an both came out of municipal water plants the Viking was on a generator in South Carolina an the Dolphin was on a pump in Mississippi both have water cooled Exhaust manifolds like a marine engine because they used the water in the water plant for cooling the 8 cylinder has 32 spark plugs 32 valves an 4 updraft carbs 2 distriburters with 18 wires coming from each 16 plug wires an 2 coil wires on each the Dolphin has 12 plugs 3 distriburters an 3 coils it is a 1928 150 HP the Viking is 1938 I have all the literature that came with engine an also a book promoting Sterling that list all the engines they had sold up to 1938 with serial numbers an locations so if you can get serial an model I can probably tell you who engine was originally sold to dont see many Sterling engines
Old 08-07-2017, 05:04:22 PM
Thanks! I'll try and get the serial number to you ASAP. How good of a runner is the Dolphin? I have no experience with marine equipment
Old 08-12-2017, 11:03:51 PM
The only ID number I could find on the tag was 031 and I believe it is a GRC 4 model?
Old 08-13-2017, 11:20:46 PM
Just looked at your post will get my book out tomorrow an see what I can find out
Old 08-14-2017, 07:23:47 PM
It is a GRC4 engine number 31 2 engines were ordered by King Knight Co on 2/27/23 engines number 030 an 031 they were sold to Associated Oil Co San Pedro Ca my GRC is number 143 it was sold on 3/11/26
Old 08-14-2017, 07:54:08 PM
Thank you so much! Hopefully we can get it out and maybe puttering away. It's come a long ways since it resides in Minnesota now.
vinco boat flying dolphin burnoil Smokstak Down Under 4 08-17-2014 11:51:13 PM
Sterling Engine Gary Bahre Hot Air Engines 3 05-11-2013 11:55:18 AM
Ricardo's Dolphin Two Cycle Engine Francis Antique Gas Engine Discussion 2 10-27-2008 04:28:00 AM
Sterling Engine??? Junkologist Small Air Cooled Gasoline Engines 4 06-11-2007 07:29:53 PM
Sterling engine almost done Tanner Remillard Antique Gas Engine Discussion 0 05-14-2007 11:21:09 PM
