Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
unknown marine engine
this thread has 2 replies and has been viewed 1237 times
Old 08-16-2017, 08:22:06 PM
Donnie Hargreaves Donnie Hargreaves is offline
Default unknown marine engine
found this today what is it .
ID:	288791   Click image for larger version
ID:	288792   Click image for larger version
ID:	288793   Click image for larger version
The Following 2 Users Say Thank You to Donnie Hargreaves For This Post:
Old 08-17-2017, 07:09:15 AM
edward moller edward moller is offline
Default Re: unknown marine engine
it looks like a ford light plant engine. uses T model ford internals.
The Following User Says Thank You to edward moller For This Post:
Old 08-23-2017, 06:25:25 AM
GeneratorGus's Avatar
GeneratorGus GeneratorGus is offline
Found this one in "97, tag says:
Farm Electric
The Ford Parts Plant
No.1304 Mod.160
Watts 1500 Volts 40 RPM 1200
Farm Electric Corp
Poole Engineering and Machine Co
Woodbury, Baltimore Maryland
I found another in "04, No. 1594
Both run and generate. Big blocky looking thing, but a hermit could live inside. Never saw that much room inside an engine. Splash oiled, I think they may have had a problem getting oil all the way to the top.
Aside from Mod T distributor and radiator caps for gas and oil outside, they have T piston and rod and, I think, modified crank and cam.I had to rig a mixer for this one, the other was all original.
GUS
Going back looking at the pictures, neither of mine have a fuel bowl, probably a later improvement.
Name:	Farm Elec..JPG
The Following 2 Users Say Thank You to GeneratorGus For This Post:
Unknown Marine Engine Mike O Antique Gas Engine Discussion 12 10-31-2016 10:01:27 PM
Unknown marine engine Nate Bolduc Antique Marine Engines and Outboard Motors 12 05-16-2014 08:42:26 AM
Unknown Marine Engine ArtLinkloader Antique Gas Engine Discussion 1 04-10-2008 09:11:17 PM
unknown marine engine Canadian made Antique Marine Engines and Outboard Motors 20 04-08-2007 08:46:41 AM
Unknown Marine Engine TomFG Antique Marine Engines and Outboard Motors 1 11-07-2006 12:53:36 AM
