Replacing cam bushing on John deer E engine
this thread has 7 replies and has been viewed 569 times
Old 10-10-2018, 11:51:50 AM
Dannyjoe53 Dannyjoe53 is offline
Default Replacing cam bushing on John deer E engine
Can you tell me I'm wanting to replace the cam bushing on my 1.5 John deer engine and wondering can it do this without removing the mag and governor assembly under the cover or does the whole engine have to come apart? Thanks for any help on this.
Old 10-10-2018, 10:41:29 PM
Arlie Levy Arlie Levy is offline
Default Re: Replacing cam bushing on John deer E engine
Yes it all has to come apart. Usually when the cam bushing is bad so is the governor bushing. Just watch the timing marks on the camshaft to crank shaft marks and the camshaft to mag gear marks. It is not hard to do. Good luck Arlie. If you have any problems call me at 608-751-3540
The Following User Says Thank You to Arlie Levy For This Post:
Old 10-11-2018, 10:59:52 AM
Banner Sponsor
The Governor has to come out but not the magneto Just be mindful of all 4 timing marks and use good steel bushings .010 undersize
The Following User Says Thank You to Mitch Malcolm For This Post:
Old 10-11-2018, 11:58:48 AM
So can I just pull the pipe plug on the bottom below governor cover to pull the pivot pin out to get the governor actuator and spring out of the way to get the cam out and I don't have to remove the mag that way? Also can I get to the governor bushing at the same time to replace it? Thanks for your help.
Old 10-11-2018, 03:28:20 PM
Tom Marshall Jr.'s Avatar
Images: 1
You may already know this , the nut on the governor is left hand thread. And when you tighten the nut go easy it doesn't take much to break it.
The Following 2 Users Say Thank You to Tom Marshall Jr. For This Post:
Old 10-12-2018, 07:42:15 AM
BMiller's Avatar
BMiller BMiller is offline
And as Tom said, it breaks easily. And what breaks is the governor drive gear. In case it happens, all those parts are available from Mitch and others. I know this because I've been there.
You can do all this with it partially disassembled. It would seem to make sense, however to take the whole thing apart and clean it up. When you do, inspect the oil pan for tiny leaks into the gas tank. I took one apart and when I held the oil pan up to the light, it was perforated with a zillion tiny holes. New ones are available with the oil cup already installed.
The Following 2 Users Say Thank You to BMiller For This Post:
Old 10-12-2018, 10:41:14 AM
Rich Mueller Sr's Avatar
Rich Mueller Sr Rich Mueller Sr is offline
Call or ask Mitch Malcom, or Jim White, or, on here,how to get those bushings out or back in!! Without the right tools, or a makeshift bolt to press those bushings in, can be a trick!! AND if you have it apart that far, might as well plan on putting a crank case bottom in, IF ANY little pockets of rust marks!! Just trying to help you out, in advance, ….
United Gasoline Engine Registry www.augermo.com
The Following User Says Thank You to Rich Mueller Sr For This Post:
Old 10-12-2018, 05:22:20 PM
Thank you for the info very helpful my first experience doing this
---------- Post added at 05:22:20 PM ---------- Previous post was at 05:17:24 PM ----------
Thanks for that important info my first time doing this
John Deer Type W engine, with oil Co tags TLM562 Oil Field Engines 4 05-13-2010 12:30:03 PM
All John Deer Ice Cream Kevin Kusel Oil Field Engines 4 07-14-2008 10:56:21 PM
John Deer Igniter Help Alan James Magnetos, Ignition Coils and Spark Plugs 7 05-31-2007 03:31:50 AM
John Deer 1-1/2 hp Bill Antique Engine Archives 2 08-09-2003 09:33:00 PM
john deer mag robert Antique Engine Archives 2 03-26-2001 07:05:10 AM
