Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Vintage Construction Equipment > Dozers and Crawlers
Dozers and Crawlers Holt, Caterpillar, Cletrac, etc.
Dozers and Crawlers
1953 International TD 6 Dozer
this thread has 46 replies and has been viewed 23281 times
Old 06-09-2013, 10:51:37 PM
Default Re: 1953 International TD 6 Dozer
OK, so the most likely scenario is on the bigger IH units you have to use a little grinder action! Good to know, now to remember.....
Old 06-10-2013, 12:04:12 AM
ronm ronm is offline
I may be able to offer some first-hand info on a TD9 if I ever get to it-the one I picked up last fall has a bad starter gear...flywheel has to come out for that, no way I'm pulling the engine just to change that gear, unless it's totally impossible any other way...got a new gear w/the tractor, the PO lost interest after he bought the gear.
Old 06-22-2013, 03:08:44 PM
Ed Christian Ed Christian is offline
Well I got new points, condenser, cap, rotor, wires and coil and now it runs! I have to get fresh diesel for it. It does not want to run on the old fuel when I switch it.
Old 06-22-2013, 05:33:29 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
You may have other issues than the old fuel, diesel fuel will still run these units no matter how old it is if it still is clean and flowable. Make sure all the switch over gear is all working and the fuel filters are clean and properly primed. When the tractor is running on gas try opening the main throttle, if it is getting diesel fuel thru the pump and the injectors the exhaust should turn black, if not it's not getting fuel. in the years we ran them we've had the compression release valves stuck open, It couldn't get enough compression to run on the diesel cycle. We also had the main plunger stick in the injection pump and keep it from working. These are a bit complicated on the switch over gear but when right it is a easy starting unit. F.J.W.
  #35
Old 06-22-2013, 06:38:34 PM
The fuel is a bit discolored. It blows some black and gray, then white raw smoke.
Old 06-22-2013, 06:59:00 PM
FWurth's Avatar
One Millionth Post
Images: 4
Check the compression relief chamber valves, their in the center of the head under the rocker assy, if it was let sit with the engine in the start mode they may be stuck in that position, that would cause it to not run on the diesel cycle and the white smoke. Good luck F.J.W.
  #37
Old 06-22-2013, 07:18:00 PM
Thanks, I will check them out. I will have to dig out the gasket material and make a new valve cover gasket. How much clearance will they have when in the proper position? I will check them out tomorrow maybe. Thanks again.
Old 06-22-2013, 08:53:55 PM
FWurth's Avatar
One Millionth Post
Images: 4
It's been so long that I don't remember the specs, It's not too critical as long as there is some clearance when they're closed. The rocker that that controls them doesn't allow for individual adjustment, it is adjusted in the linkage.
  #39
Old 06-24-2013, 09:47:05 PM
I would say set them .020" AVERAGE across all four and let it be unless you have issues. Since these merely open and close once on each start and shutdown cycle, all you have to do is make sure the parts don't grow enough when they are hot to open it back up on their own.
The Following 2 Users Say Thank You to Brasherman For This Post:
  #40
Old 07-07-2013, 06:19:20 PM
Well, I did not have to pull the valve cover. I accidentally figured out how to start it. I was not working levers properly. I thought the one lever was a throttle until I found out it shut my gasoline off and gas came when I had the bowl drain open when moving the lever. WOW! I figured it out, then it ran on diesel! I had been flooding it out before with both fuels when the lever was half way in between. So no throttle , it runs on the governor. I learning. THANKS GUYS & GALS!
T4 International Dozer Tooldie Dozers and Crawlers 8 01-13-2013 05:56:26 PM
looking for old dozer Toyotabob Smokstak Down Under 0 07-18-2012 05:15:49 PM
Need Roller for my Dozer wilson Ross Dozers and Crawlers 1 12-02-2010 10:48:54 PM
International Harvester TD-9 Dozer Sonny Reese Dozers and Crawlers 7 02-08-2010 08:31:39 PM
Rinel Dozer Beth V Dozers and Crawlers 5 05-04-2008 05:17:40 PM
