Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Vintage Construction Equipment > Dozers and Crawlers
Dozers and Crawlers Holt, Caterpillar, Cletrac, etc.
Dozers and Crawlers
1953 International TD 6 Dozer
this thread has 46 replies and has been viewed 23321 times
Old 07-08-2013, 06:51:50 PM
ronm ronm is offline
Default Re: 1953 International TD 6 Dozer
Ed, if your starting linkage is all working, there's no way it can burn gas on the diesel side, the butterfly in the manifold closes off all airflow through the carb...that lever on the carb should be hooked to part of the starting linkage, so it holds the float valve closed to prevent the carb from flooding when you change over to diesel. Sounds like you may have issues or a "missing link" with the changover mechanism still, if the carb lever isn't hooked to anything. That linkage is subject to sticking & hanging up, it's a fairly common problem w/those engines...
The changeover lever on the dash is the only thing you should have to manipulate, other than the Diesel throttle, when you switch over.
The Following 3 Users Say Thank You to ronm For This Post:
Old 07-08-2013, 09:24:43 PM
Clarification:
Actually, I kinda said it backwards-the butterflies close off the manifold when you switch to gas, & diverts the airflow thru the carb...when on diesel, the carb passage is bypassed & no air goes thru it...
Here's a page from an old IH brochure, if it's clear enough it shows the general idea...(thanks to MDiesel from the Redpower board for the page...)
Name:	International Diesels engines and power units page 5.jpg
The Following 2 Users Say Thank You to ronm For This Post:
  #43
Old 07-09-2013, 06:30:34 PM
Ed Christian Ed Christian is offline
When I throw the lever all the way, it does not mix fuels. Only half way in between is when both fuels mix.
Old 07-09-2013, 06:48:24 PM
Yeah, you still have a problem w/the changeover mechanism-shouldn't be a "halfway" point-it should be all or nothing-click in when you pull it back & trip w/a pretty loud "snap" when you push it into diesel position. The linkage is probably binding or gummed up...
If you get on Redpower, construction equipment forum, & do a search for "flipper thingy", you'll find a lot of discussion on this subject..
  #45
Old 07-09-2013, 07:10:22 PM
The linkage was froze up and I freed it up. I had to heat it a couple of times and put the P.B. B'LASTER to it. I am planning on taking it back apart and put anti-seize on it.
Old 09-25-2016, 08:47:34 PM
jmertz jmertz is offline
any body know where I can get the four small springs for a TD 6 12 inch rockford over center clutch pressure plate?
Old 05-20-2017, 04:06:56 PM
mschreiber mschreiber is offline
is ed still around? and his td6…...
T4 International Dozer Tooldie Dozers and Crawlers 8 01-13-2013 05:56:26 PM
looking for old dozer Toyotabob Smokstak Down Under 0 07-18-2012 05:15:49 PM
Need Roller for my Dozer wilson Ross Dozers and Crawlers 1 12-02-2010 10:48:54 PM
International Harvester TD-9 Dozer Sonny Reese Dozers and Crawlers 7 02-08-2010 08:31:39 PM
Rinel Dozer Beth V Dozers and Crawlers 5 05-04-2008 05:17:40 PM
