Onan 12.5JC Sorting it Out
this thread has 77 replies and has been viewed 2806 times
Old 02-10-2018, 10:21:35 AM
consolenut consolenut is offline
Default Re: Onan 12.5JC Sorting it Out
Correction that was a typo. I got L0 to the lug in the bottom of the box. That connection was at 127 volts.
But yes I will double check the numbers
When I started re-configuring I assumed L0 was the neutral. But it now seems the lug in the bottom of the wiring box is the Neutral/Ground. Am I missing something? I posted a small portion of the configuration drawing. I referenced it versus the schematic on the cover of the unit.
Old 02-10-2018, 10:50:07 AM
lets start over here- please list the voltages you have
L1 to L2
L1 to L0
L2 to L0
If it is correctly wired, L1 to L2 will be twice the voltage of the latter measurements. L0 is the neutral, and grounding same should not affect the measurements above.
Old 02-10-2018, 11:18:34 AM
L1 + L2 is 240 volts
Ill check the voltages between L1 & L0 and the same with L2 & L0.....those connections if wired correctly should be 120V each? Correct?
So my first thought was correct. L1 + L2 are my hots. And L0 goes to the neutral Bar in my 70 amp panel.
Old 02-10-2018, 11:53:02 AM
here you go
Name:	double delta.png
  #45
Old 02-10-2018, 12:03:02 PM
EnginePat EnginePat is online now
Reconnection diagram
Pat
5GO 3/RA
7.5 jb's x4
6.0 DJE X 1
The Following User Says Thank You to EnginePat For This Post:
  #46
Old 02-10-2018, 12:12:01 PM
I used this page from the manual. My voltage code is 18 and i used double delta. I think im on same page.
Old 02-10-2018, 01:46:16 PM
armandh armandh is offline
seems to be 120/208Y with all the leads flipped from the drawing.
double delta can be the standard connection or one of 11 other ways
the standard connections will save much confusion later
by using this free advise, you, your heirs, etc
absolve, save, and hold harmless the advisor.
CAVEAT EMPTOR
YMMV
Old 02-10-2018, 02:06:19 PM
So which drawing are you referring to armandh
Old 02-10-2018, 02:29:08 PM
Hmm after reviewing a few things in the drawings it mentions v1-V4. After looking at everything. The jumpers appear to me to be v1-v2. Did i miss something pic attached
Old 02-10-2018, 07:38:48 PM
zuhnc zuhnc is offline
V4 is the COMMON. Jumper is from V4 to any of the other three, per diagram. V1-V2 is incorrect. zuhnc
