Wisconsin Engines
Wisconsin 12HP Twin Cylinder w/magneto and generator
this thread has 2 replies and has been viewed 1766 times
Old 02-04-2013, 05:19:16 PM
Cmdangelo83 Cmdangelo83 is offline
Default Wisconsin 12HP Twin Cylinder w/magneto and generator
The Title says it all - well almost. I have a 1950's generator set powered by a 12 HP Wisconsin engine mounted on a serious frame. Interesting engine - both cylinders are at TDC at the same time, one in compression, the other at exhaust. It is a hand crank start. The generator has massive windings. I bet the who rig weights in at nearly 400 lbs. the engine runs for short bursts, but the carb is in poor shape.
Is this thing of interest to anyone?
Old 02-04-2013, 07:39:08 PM
Zira Zira is offline
Default Re: Wisconsin 12HP Twin Cylinder w/magneto and generator
I would guess this is supposed to run at 1800 rpm? These make good users as well as neat collectables. I have an AGH-powered Winco that runs at 1800 rpm that is my main back-up generator at the house.
Old 02-05-2013, 07:32:59 AM
Phil P Phil P is offline
A word of advice.
Donít run that engine until you remove the line from the back of the governor housing and make sure the oil pump is working.
Remove the line and the spark plugs. Spin the engine with the crank until oil comes out of the line. It will be a pulse not a stream.
Phil P
The Following User Says Thank You to Phil P For This Post:
Root & VanDervoort 12hp magneto gear Patrick M Livingstone Smokstak Down Under 3 12-26-2012 01:25:31 PM
Witte 12HP AC Generator 7.7KW Diesel campthunderbirdnm Generators & Electric Motors General Discussion 0 09-14-2012 09:40:56 AM
Wisconsin, unknown twin, weak spark on one cylinder Cheddarpecker Magnetos, Ignition Coils and Spark Plugs 9 01-05-2012 07:36:04 PM
Associated 25 Twin Cylinder DavidRaines Antique Gas Engine Discussion 7 06-23-2010 10:40:59 PM
Kohler 12HP K301 cylinder pitting after boring? fordiesel69 Small Air Cooled Gasoline Engines 8 06-01-2009 02:00:58 AM
