Twin City 60-90 Dimensions and Measurements
this thread has 7 replies and has been viewed 1943 times
Old 11-04-2011, 10:51:56 PM
twotoots2 twotoots2 is offline
Default Twin City 60-90 Dimensions and Measurements
Hello,
Would any of you know where I could find some basic dimensions for a Twin City 60-90? Length, height, width, wheelbase, wheel sizes, etc., and/or any other critical dimensions would be very helpful. I can find some specification type information, but very little which references it's size. I am wanting to build a scale model of that impressive tractor, so this information would be extremely valuable.
Thanks!!!
Dan
The Following 3 Users Say Thank You to twotoots2 For This Post:
Old 11-04-2011, 10:59:08 PM
OTTO-Sawyer's Avatar
Default Re: Twin City 60-90 Dimensions and Measurements
Can't help you with the dimensions, but I'm already looking forward to seeing the upcoming progress reports on the buildup when you get started on it.
The work you've shown in the 27-44 twin city thread is pretty impressive.
Old 11-04-2011, 11:01:53 PM
A Martinson A Martinson is offline
Images: 39
Engine 7.25x9"
Drivers 84"x30"
Fronts: 42"x12"
Pulley: 23"x10.5"
Length: 262"
Width: 114"
Height: 122"
The Following User Says Thank You to A Martinson For This Post:
Old 11-05-2011, 04:09:41 AM
If you havent already seen it, take a look at these two model 60-90s on e-bay.
http://ebay.com/sch/i.html?_nkw=twin+city+tractor
They are a bit crude, but also cute given its humble beginings by an enthusiast much like yourself. These are poured castings...I see you do it a bit different.
Any chance you would make more than one?
I am looking forward to seeing what you come up with
Tony
The Following User Says Thank You to Tony Thompson For This Post:
Old 11-05-2011, 07:03:56 AM
acat65 acat65 is offline
why don't you go to rollag and look & measure the real thing. Gene
The Following User Says Thank You to acat65 For This Post:
Old 11-05-2011, 12:35:48 PM
Gene, I wish I could, and I might. Since its on Labor Day time frame... It could be doable. Its a two day trip from WY. I do have a friend in Milaca and it would be cool to see him again.
---------- Post added at 09:31 AM ---------- Previous post was at 09:29 AM ----------
AM, Thanks soooo much for the info. Its a great start!!!
---------- Post added at 09:35 AM ---------- Previous post was at 09:31 AM ----------
Tony! Thanks for the suggestions! I took a good look at the sand cast TC's and shook my head. Nothing wrong with them or the neato factor of having a model 60-90 out there, but in order to customize it, all I would really be able to use are the front wheels.... Pricey for just that.
I really want to scratch build the entire model starting with the engine. May CNC some components, but I really hate programming G code!!!
The Following User Says Thank You to twotoots2 For This Post:
Old 11-05-2011, 12:37:30 PM
Chris Epping's Avatar
Chris Epping Chris Epping is offline
Images: 41
Quinter KS is a couple hundred miles closer. You could probably get in to see one in the process of being put together there.
Chris
The Following User Says Thank You to Chris Epping For This Post:
Old 11-05-2011, 12:40:26 PM
Thanks Otto and Thanks Chris!
Twin city 16-30 sebes78 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 07-22-2011 07:52:41 PM
Twin City 16-30 Steve Barr Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 23 01-03-2010 05:55:33 PM
Twin City LT David Parfitt Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 17 12-02-2008 09:28:42 PM
17-28 ty twin city Bear Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 12 01-14-2006 12:00:12 PM
500 H.P. Twin City Tanner Remillard Steam Stationary Engines, Traction Engines, Steam Boats 2 07-17-2005 12:13:02 PM
