1929 F-M 10HP Z needing repair list
this thread has 4 replies and has been viewed 1850 times
Old 10-25-2005, 10:32:52 AM
NAMPeters
Question 1929 F-M 10HP Z needing repair list
It is time to drag out the F-M and start the restoration. The engine is missing a number of parts and to aid in the search a Repair Parts List would be handy. I have one No. 8410 but it is for an older version of the engine than mine. What is needed is the F-M list number that matches my engine, which is the reason for this post. Does anyone in engine land know what that list number is and willing to share same?
This is one of two engine projects, the other is a Bean/Witte but we will get to that later.
Thanks in advance, Neil Peters
Old 10-25-2005, 11:20:09 PM
Doug Waggonner's Avatar
Thumbs up Re: 1929 F-M 10HP Z needing repair list
Here is a link http://www.edgeta.org/oldsite/fmdates.htm It shows production dates via serial #'s to to 1948. Do you have a picture of your engine?
Old 10-26-2005, 03:12:16 PM
NAMPeters
Photo Re: 1929 F-M 10HP Z needing repair list
Here are a couple of shots of the block and crank with flywheels sitting out in the yard. It is dessert here so it is not too hard on things. Other stuff is in a storage container. Key things missing at the moment are cylinder head, gov, mag and bearing caps. This is a challenge project but I love the sound of these engines so will press forward.
Neil Peters
Name:	STAK DCP_0459.jpg
ID:	4641   Click image for larger version
Name:	STAK DCP_0454.jpg
Old 10-27-2005, 11:47:00 AM
Talking Re: 1929 F-M 10HP Z needing repair list
I think I might have a cyl head for your engine if you will give me some deminsions, like bore size,and outter cyl size, distance between head studs, ect. And I pretty sure I carb.
Old 10-29-2005, 12:40:41 AM
NAMPeters
Default Re: 1929 F-M 10HP Z needing repair list
Some data pertaining to the engine: S/N 736219, Bore 7", Block diameter at interface 11 1/8",stud spacing 5 1/4", stud length 5" except 6" at 4:30 position facing engine, and stud diameter 7/8". I hope this is useful.
Neil Peters
Tags
Fairbanks
Needing 35 Hp Superior valve rocker arm 82lagoon Oil Field Engines 10 03-15-2008 11:34:21 AM
Needing a new shaft......... Sam Simons Garden Tractors / Mowers / Scooters 1 03-10-2008 01:50:37 PM
Needing Help To Identify This Engine Donnie Devore Sr. Antique Gas Engine Discussion 4 06-20-2007 09:23:44 AM
F-M 10HP (1929) The Beginning NAMPeters Antique Gas Engine Discussion 0 06-18-2007 10:17:55 AM
Needing 32 volt bulbs, ect. R Lee Generators & Electric Motors General Discussion 7 07-13-2001 12:34:46 PM
