Onan 6.5 NH-3CR J, picked up free out of a yard. Nothing's ever free...
this thread has 86 replies and has been viewed 3455 times
Old 08-25-2018, 11:08:50 AM
Pauls12 Pauls12 is offline
Default Re: Onan 6.5 NH-3CR J , picked up free out of a yard. Nothing's ever free...
HI , I have had good luck with Dupli-color # DE 1617 I got it at NAPA or anyone that can get it.
The Following User Says Thank You to Pauls12 For This Post:
Old 08-25-2018, 12:10:03 PM
Newoldstock Newoldstock is offline
Originally Posted by grif View Post
Seems like the model airplane folks use plain old antifreeze in a crock pot over night to clean up aluminum engine parts?
I've done it for years, slow but effective 70% of the time.
For those really ugly carbs I use some caustic aluminum rim cleaner,
That stuff is eating the aluminum and the dirt so be careful and never leave it sit without you there watching it.
Then there is the nuclear option:
Warm the carb with a torch in the specific areas where the circuitry is and the clog is suspected.
Hot enough to cause anything in there to melt/burn but no so hot to melt metal.
Then as it cools back in dip of rim cleaner.
Its harsh but sometimes works.
The Following User Says Thank You to Newoldstock For This Post:
  #33
Old 08-25-2018, 12:20:44 PM
AngolaGravely AngolaGravely is offline
I field strip and drop it into this:
https://www.ebay.com/itm/2L-Industry...0AAOSwYVlaA8h5
fill with water and 2-4 drops of dishsoap,
Set temp at 90C, tIme for 30min and walk away.
Haven't found one that didn't come perfectly clean yet.
Old 08-25-2018, 03:23:02 PM
I found the carb that came from a nh.. complete with manifold that has the adapter.. it looks kinda beat up.. but the butterfly and choke move easy.. if your interested I will take it apart and see what the inside looks like
ID:	317045   Click image for larger version
ID:	317046   Click image for larger version
  #35
Old 08-25-2018, 08:10:56 PM
RB855 RB855 is offline
Have some carb issues yet, wont start without assistance. It did however start without surprises. It even tried to putt to a start on a bit of carb cleaner vapor that was hanging out in the intake and surprised me. No smoke, barely any blow-by out of the breather. Have not loaded it yet either, as this is a test and flush run. Sounds like the rear bearing in the gen head might need replaced (squeaks and sounds rough when running), and the valves are going to need an adjustment. Going to run it one more time and swap the oil. Stuck a big honkin neo magnet on the drain plug, so well see if anything comes out. The audio makes it sound rougher than it really is. All I have for a muffler right now is a burned out home made glasspack off a motorcycle too.
https://youtu.be/SQ_JBPk3iNU
ID:	317059   Click image for larger version
ID:	317060   Click image for larger version
The Following User Says Thank You to RB855 For This Post:
  #36
Old 08-25-2018, 08:13:47 PM
Apart from what may be some main jet issues, it seems this walbro wants to run. I ordered up a choke from fleabay but im missing the thermostrip assembly yet. Assuming there isnt something catastrophically wrong with this one, I might be ok. Appreciate the look though.
Old 08-25-2018, 09:32:30 PM
Pauls12, Guess I just ordered a case of the weird colored stuff. Whoops. Lets find out!
Also, trying to track down the bearing lookup number for the brush end bearing in the alternator head Part Number 510-0074 . $55 seems kinda silly for a sealed ball bearing, heck I could pick up a sealed roller bearing for that price. Looks a little interesting to replace, so having less parts on the bench for more than an hour is a good thing lol.
Old 08-25-2018, 09:55:22 PM
turtmaster turtmaster is offline
I think that it takes the same end bearing as the 4/5 cck
Here is the bearing I got for my 4cck it is a "fag" "6205.2rsr.c3"
You will have to carefully grind with a Dremel a "slot" into the outside of the bearing,
For the anti rotation "clip", careful taking off the the clip, and don't lose or break it, I don't think that they sell them any more.
The Following User Says Thank You to turtmaster For This Post:
  #39
Old 08-25-2018, 09:55:34 PM
Somewhere here in the 46 pages of JohnnyC's build thread he has a pretty good explanation of replacing the rear bearing:
https://www.smokstak.com/forum/showthread.php?t=153885
The Following 2 Users Say Thank You to nothingbutdarts For This Post:
  #40
Old 08-25-2018, 10:11:54 PM
6205 is the magic number. Thanks! The notch seems a bit of silly nonsense. A readily available bearing with a dimple and a setscrew would have made sense. Looks like a fun little project, but I intended to get in there and do some contact cleaning anyways. Its on page 13 of JohnnyC's thread, for anyone who might be following along. I intend to do a load test tomorrow after poking the carb to see what happens before ripping the back end off it. Thanks!
picked up a free onan 705 cw YellowLister Onan Generators 36 04-28-2016 07:32:38 PM
*FREE*FREE*FREE* (well, I'll trade for a cup of coffee) JohnnyC Onan Generators 14 07-02-2015 09:25:33 AM
Onan 5.0CCK-3CE/8800R - picked up for free... where do I start? abruckse Onan Generators 45 06-25-2015 05:32:38 PM
Onan- Look what I just got for free Jim Marcozzi Onan Generators 20 10-31-2014 11:41:32 AM
Free engine I picked up today darrin Antique Gas Engine Discussion 15 03-19-2008 11:09:51 PM
