Oil Field Engines
Go Back   SmokStak > SmokStak® Antique Engine Community > Oil Field Engines
Oil Field Engines A gathering place for OFES members otherwise known as "Oafs". Basically, if you like "BIG OLD GREASY RUSTY OIL FIELD ENGINES, you're in the right place. Founded by Russell Farmer.
Oil Field Engines
Reid Flywheel Wanted
this thread has 5 replies and has been viewed 1054 times
Old 11-06-2017, 01:48:21 PM
Dazzla Dazzla is offline
Default Reid Flywheel Wanted
Gents
I've got a Reid with two bust spokes in the charging side flywheel. I've discussed ways of repairing it, but I keep coming back to my preference of replacing it with sound one. Not so much of an issue, other than the fact my engine is over here in England!
So, is there anyone who can help me find a 5'6" wheel for a 25hp engine? If I can find one I might be able to get it shipped over with some other stuff through a friend of a friends friend. But before I worry about logistics, is there one available anywhere?
Cheers
Dazzla
Old 11-06-2017, 06:03:18 PM
Default Re: Reid Flywheel Wanted
You might try and contact Lee Pederson, a sponsor here on the Stak. I know Lee has shipped many things to your side of the big pond. He might be able to locate one thru his contacts stateside.
You will need to know if left or right hand, approximate age and crankshaft diameter and flywheel width, besides flywheel OD for starters. there should be one around, there were quite a few made.
Old 11-07-2017, 08:35:04 AM
KyleBlankenship's Avatar
KyleBlankenship KyleBlankenship is offline
unfortunately you're about two months late. there were several that sold for scrap price at the Thornhill auction.
I don't think it matters if you have a left or right hand engine the flywheels are the same on both.
I know rosevink has contacts over your way and send containers fairly frequently so I don't think getting one shipped would be much of an issue
there are a few guys that advertise in the large engine section that have a lot of oil field engine parts. I wouldn't think a good flywheel would cost a whole heck of a lot.
good luck
Old 11-07-2017, 05:30:05 PM
Thanks for the replies. I appreciate I need to give more detail, but I thought I'd test the water first to see if someone can help.
Cheers
Dazzla
Old 11-13-2017, 11:28:40 PM
The flywheels are different depending on whether the engine is right or left ( location of counterweights and charge piston pin). Stand in front of the engine facing the cylinder "head". If the power pulley is on the left then it is a lefty, vice versa for right.
A 25 flywheel will be hard to find. Good Luck. Bill Klein
Old 11-29-2017, 02:12:37 PM
This is the engine it's for. Some of you may recognise it.
Cheers
Dazzla
Reid Flywheel Christian Berlin Oil Field Engines 1 06-09-2009 08:04:22 PM
Reid Flywheel Christian Berlin Antique Gas Engine Discussion 3 06-09-2009 07:29:13 PM
Reid Flywheel removal and replacement Keith Kinney Oil Field Engines 9 01-28-2009 09:57:47 AM
Reid HP by flywheel diameter? Steve Tachoir Oil Field Engines 2 09-29-2007 08:16:13 PM
Reid flywheel lbarnica Oil Field Engines 0 02-13-2007 11:51:59 AM
