Oil Field Engines
Go Back   SmokStak > SmokStak® Antique Engine Community > Oil Field Engines
Oil Field Engines A gathering place for OFES members otherwise known as "Oafs". Basically, if you like "BIG OLD GREASY RUSTY OIL FIELD ENGINES, you're in the right place. Founded by Russell Farmer.
Oil Field Engines
Fairbanks Morse 346 Year Id
this thread has 20 replies and has been viewed 2967 times
Old 08-05-2009, 10:38:25 AM
fire96 fire96 is offline
Default Fairbanks Morse 346 Year Id
I have a fairbanks morse 346 that the tag is missing. Is there another way to find out the year?
Old 08-05-2009, 11:00:26 AM
NAMPeters
Default Re: fairbanks morse 346 year id
A picture or two would sure help.
Old 08-05-2009, 04:23:34 PM
here are the pictures
ID:	60226   Click image for larger version
Old 08-05-2009, 04:25:56 PM
Here are two more pictures.
ID:	60228   Click image for larger version
Old 08-05-2009, 05:44:48 PM
Ray Cardoza's Avatar
The serial # should be stamped by the carb side flywheel on a little spot. I know thats where it is on the 118's so it should be there also.
Old 08-05-2009, 06:57:57 PM
Doug Waggonner's Avatar
Nope, on a 346 the serial # is on the end of the crankshaft. Dont know why they thought that was a good idea because that is a replaceable part.
The Following User Says Thank You to Doug Waggonner For This Post:
Old 08-07-2009, 12:53:02 PM
Thanks for the replies!! If there are any more out there I would like to here from you!!
Old 08-09-2009, 10:39:15 AM
Pete Mueller Pete Mueller is offline
Default Re: Fairbanks Morse 346 year id
The serial number is stamped on a milled flat area just forward (head end) of the crank case cover on the top side of the engine.
Old 08-09-2009, 11:08:21 AM
Nope, a 346 is different than all the other ZC's when it comes to the location of the serial # It will be stamped on the end of the crankshaft.
Now if your engine is a BELL mfg'd "FM Copy" all bets are off.
Old 08-09-2009, 05:37:57 PM
Reed Engine's Avatar
You learn something every day. I thought it was on top of the crankcase.
Fairbanks Morse Z year of engine gt4 Small Air Cooled Gasoline Engines 3 09-13-2015 04:06:48 PM
6-7HP Fairbanks Morse Year? jake1297 Antique Gas Engine Discussion 6 01-24-2012 11:15:26 AM
Need Fairbanks Morse YEAR grant michigan Antique Gas Engine Discussion 5 03-31-2011 07:33:43 PM
Year of Fairbanks Morse Z Beez Antique Gas Engine Discussion 4 12-03-2009 10:19:44 PM
10 hp fairbanks-morse year? Dan Grace Antique Gas Engine Discussion 2 03-06-2006 06:44:45 AM
