Associated Jerry Boy Engine
this thread has 8 replies and has been viewed 3203 times
Old 11-12-2010, 11:35:19 PM
Brian Flatmoe Brian Flatmoe is offline
Default Associated Jerry Boy Engine
We made a junking run to Sask. Canada the middle of this week for some tractor parts and an added bonus was several gas engines. A stover tagged as a T Eaton, a Fairbanks Morse 3HP Z I think as it's missing it's tag and this air cooled Associated Jerry Boy. It was in an old shed but has much of it's original paint as you can see. Had never heard of a Jerry Boy. Are these very common? It has been adapted to a sparkplug and there has been some repair done to the governor but overall it seems to be in fairly decent shape.
ID:	92417   Click image for larger version
ID:	92418   Click image for larger version
The Following 8 Users Say Thank You to Brian Flatmoe For This Post:
Old 11-13-2010, 12:13:48 AM
Bob Geyer Bob Geyer is offline
Default Re: Associated Jerry Boy engine
Brian,
Check Wendells. On page 34 you'll find a Chore Boy thats really similar.
Bob
Old 11-13-2010, 09:10:59 AM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is offline
I do not have this "Jerry Boy" manual, only these not so great pictures of its cover page.
Denis Rouleau
ID:	92425   Click image for larger version
The Following 11 Users Say Thank You to Denis Rouleau For This Post:
Old 11-13-2010, 09:25:27 PM
Mike O's Avatar
Mike O Mike O is offline
As you can see from the tag, Jerry boys are RR car engines, They can run foward or backwards by changing the position of the cam, Running foward they used the mag but you have to use a buzz coil to run it backwards. I am allyays on the look out for odd assoicated engines like this Jerryboy or a Jack boy. Should you be interested in selling it please let me know!
The Following User Says Thank You to Mike O For This Post:
Old 11-13-2010, 11:14:31 PM
Will Batty's Avatar
Will Batty Will Batty is offline
Brian
You should of left that junk in Saskatchewan!
Oh well I guess I can't find all the engines, congrats, don't know much about that Jerry Boy but it looks good!
Old 11-14-2010, 07:01:52 AM
LarrapMan's Avatar
LarrapMan LarrapMan is offline
Default Re: Associated Jerry Boy Engine
Hello Mike,
I don't think they were all supplied with the reversible cam and some just had larger flywheels as most people discovered you could just put a twist in the belt and I am guessing the hand car companies incoorperated a cunning belt arrangement in thier design to make it easier so people could just mount any engine.
Also as with all Associated stuff the Mag would have been an extra so I guess most people would have just used a LT battery coil rather than spending $10 on a magneto that would only work half the time and they would need to buy batteries anyways if they wanted to get home again!
I have a Cam which someone forced on me when they couldn't get their engine going so I swapped it for a standard one. I'm going to fit it to a 1912 Hired Man I just bought this winter. I found out that they could just be specified on any engine (1.75 or 2.25). May I refer you to this ealier thread - http://www.smokstak.com/forum/attach...6&d=1277116041
Joe
The Following 2 Users Say Thank You to LarrapMan For This Post:
Old 09-12-2012, 07:32:07 PM
Bruce Flatmoe Bruce Flatmoe is offline
We have been working on this engine. The paint looks really nice and we will be leaving it original. So far it has been cleaned and wiped down with lindseed oil cut with mineral spirits. Can anyone direct me on where to go to find igniter parts or a replacement igniter? This one had one hole welded shut when they converted it to a spark plug motor.
Old 09-12-2012, 08:15:26 PM
DavidRaines DavidRaines is offline
Bruce, Bill Graves should have the parts you need. 315-245-0589.
Dave
Old 09-12-2012, 08:16:40 PM
Thank you for the lead!
Jerry Howell's "Powerhouse" engine Tom Jamboretz Scale Model Engineering 3 01-06-2010 04:06:50 PM
Jerry Howell has passed away Tom Jamboretz Scale Model Engineering 3 09-02-2009 05:29:55 PM
Associated Jerry Boy??? Gasengin Hit & Miss Gas Engine Discussion 6 07-14-2006 09:07:00 PM
Contact: Jerry Terrell mitch malcolm Antique Engine Archives 0 05-07-2003 09:05:42 AM
phone# for jerry terrell huck Antique Engine Archives 1 09-22-2002 09:49:22 PM
