Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Model 82 Core
this thread has 7 replies and has been viewed 1394 times
Old 12-12-2015, 06:24:18 PM
Justin1 Justin1 is offline
Default Model 82 Core
Hi there. Does anyone have a model 82 ignition core or maybe even an upright?
The one I have is rubbed down really bad on the ends and I think that is why I can't get my upright to work.
Justin
Old 12-13-2015, 09:04:02 AM
Clement Rook Jr. Clement Rook Jr. is offline
Default Re: Model 82 Core
justin, what are you calling a ignition core?
Old 12-13-2015, 09:16:15 PM
Kevin Weis Kevin Weis is online now
Think he means the laminated armature. Justin, if that's it I may have one.
Kevin
Old 12-14-2015, 07:25:45 PM
The laminations.
---------- Post added at 06:25 PM ---------- Previous post was at 06:22 PM ----------
Hi Kevin. That would be super awesome if you have one. I could even give you the one I have now.
My number is 2023020676 and you can txt me or call and my email is justinralston@verizon.net
Old 12-15-2015, 12:49:46 AM
Justin, I'll send you an email tomorrow with picture attached to make sure this is what you need. The coil goes with it. I don't have a model 82 anymore so don't need it. I believe what I have is the earlier version of coil. I think the armature (laminations) are the same though.
Regards, Kevin
Old 12-16-2015, 09:09:57 AM
Hi Kevin. I got my ignition to work with my 82 coil which I swapped out last night. It's an upright I'm having trouble with. Does your coil have two metal studs sticking out of the actual coil? The other coil I had did not and that's why it didn't work. I don't understand it.
Justin
Old 12-16-2015, 05:01:59 PM
Justin, the coil has the section (shoe) on each end that magnets on the flywheel interface with. I didn't get around to sending you a picure yesterday but will try to get to it this evening. They actually are fingered to the part of the armature that goes through the coil. Actually I guess I'm assuming your talking about a magneto upright. They would use the same coil I believe that the early model 82 used. Right though if those two end sections weren't there, which is really odd, there's no way possible it would have run. The armature shoes should have just a hair gap or so between them and the flywheel magnets when they pass over them. Hope this helps but it looks like you got it figured out. If you still need that part PM me. I can either send it to you or you seem close enough to pick up. Let me know.
Kevin
Old 12-16-2015, 08:25:22 PM
Justin, figured I would post pictures here so others could see. Hope this is what you have. Let me know if this will work for you.
Kevin
Name:	82 coil 001.jpg
ID:	241359   Click image for larger version
Name:	82 coil 002.jpg
ID:	241360   Click image for larger version
Name:	82 coil 003.jpg
Coil core crobis r Magnetos, Ignition Coils and Spark Plugs 4 03-05-2014 04:26:30 PM
IHC W-30 Radiator Core Jason Dahm Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 07-09-2012 05:13:16 PM
Electromagnet core Ralph Leonard Antique Engine Archives 7 05-14-2003 05:04:09 PM
Hard Core Or soft Core? J . morris Antique Engine Archives 0 01-12-2000 06:52:47 PM
Hard Core collectors J . morris Antique Engine Archives 6 01-11-2000 03:19:19 AM
