Metal Tractor Wheel or Metal Pulley? #1
this thread has 17 replies and has been viewed 2229 times
Old 09-15-2017, 01:30:20 PM
rknarr2 rknarr2 is offline
Default Metal Tractor Wheel or Metal Pulley? #1
I am not sure what this is but I thought maybe a metal tractor wheel or
maybe a metal pulley like goes on a saw mill? Thank you.
Regards,
Rob
ID:	291255   Click image for larger version
Old 09-15-2017, 01:46:05 PM
Default metal tractor wheel or metal pulley? #2
I was wondering if this is maybe a metal tractor wheel or metal pulley?
Thank you.
Best Regards,
Rob
ID:	291257   Click image for larger version
ID:	291258   Click image for larger version
Old 09-15-2017, 01:51:27 PM
Default Re: metal tractor wheel or metal pulley? #1
Adding a picture showing the width of this metal tractor wheel or metal pulley for possibly a vintage saw mill? Thank you.
Best Regards,
Rob
Old 09-15-2017, 03:24:50 PM
Heins Heins is offline
They are flat belt pulleys.
Old 09-15-2017, 10:44:54 PM
Yep, flat belt pulley, I call them a split pulley, maybe there is a more proper name?
Old 09-18-2017, 05:50:43 AM
Wayne Riedlinger Wayne Riedlinger is offline
Thats the same type of pulley as our Wallis tractor has on it.
Old 09-18-2017, 08:19:55 AM
Malcolm Robinson Malcolm Robinson is offline
Manufactured by The American Pulley Company of Philadelphia PA.
Malcolm.
Old 09-18-2017, 01:55:24 PM
Russ Hamm's Avatar
Definately line shaft/machine pulleys as i don't see splines.
Old 09-18-2017, 02:44:21 PM
Oldtech Oldtech is offline
Definitely looks Wallis
Old 09-19-2017, 05:40:24 AM
Default Re: Metal Tractor Wheel or Metal Pulley? #1
The style of pulley is the same as the ones put on Wallis tractors before they went to fibre pulleys. Over the years I have seen many varying diameters, even bought some thinking they would fit a Wallis only to get them home and find out the diameter is wrong for the linkage and pulley brake.
I presume they were used on various other non tractor applications like the line shafting pulleys as suggested.
So a diameter measurement of this pulley would determine if it's Wallis tractor or not.
Malcolm
Old 09-20-2017, 10:36:52 AM
The Wallis pulley is 18 inches in diameter.
Malcolm.
Old 09-20-2017, 01:33:17 PM
The pulley on my 20-30 Wallis looks to be 18-3/4 by 7-1/4; but I didn't have my glasses when I was at the shed. Shaft might be 2".
Old 09-20-2017, 08:42:02 PM
I've got 2 other pulley kivkig around of the same style. One is about 24 inch by 6 inches wide and the other is about 12 inches by about 8 wide.
Old 08-26-2018, 04:22:10 PM
The rim diameter is about 12" diameter. Would that make the rim from a Wallis tractor or not? Thank you. Rob
---------- Post added at 04:19:10 PM ---------- Previous post was at 04:16:23 PM ----------
Malcolm
The pulley has a 12" diameter. Would this pulley be from a Wallis tractor or not. The other pulley has around 15 3/4" diameter. Would this pulley be from a Wallis tractor or not. Thank you for your assistance in this request. Regards, Rob
---------- Post added at 04:22:10 PM ---------- Previous post was at 04:19:10 PM ----------
Malcolm.
At least I know it is not from a wallis tractor. Possibly from a line shafting pulleys.
Old 08-27-2018, 01:45:19 AM
The 12" diameter rim x 4 3/4" across the outside of the rim. The shaft hole is 1 3/4" diameter. The rim is put together in halves because there are 2 sections. Even the shaft hole is put together in halves. The shaft hole is surrounded by 2 metal rings and then by a third metal ring that is bolted together on each side like a clamp. I hope this helps with identifying the Metal Tractor Wheel or Metal Pulley? #1.
The other rim is 15 3/4" diameter x 4 1/4" across the outside of the rim. The shaft hole is 1 1/4" diameter. On one of the spokes is imprinted 1065. The ring around the shaft hole has a hole to screw in a screw or a bolt inorder to secure a shaft inside the shaft hole of the rim. I hope this helps with identifying the Metal Tractor Wheel or Metal Pulley? #2
Thank you for assistance in these requests. Regards, Rob
Old 08-27-2018, 12:37:03 PM
The first 2 attachments shows one of the cuts between the halves of outside. The 3rd attachment shows the cuts between the halves of inside shaft hole and the double metal rings and the clamp that is bolted on both sides around the outside of the shaft hole. The 4th attachment shows the 2 cuts on the edges of both sides of outside as well as the inside cuts on the inside and the double metal rings and the clamp that is bolted on both sides around the outside of the shaft hole as I described in the forementioned response. I hope these pics help with the forementioned response to #1 rim. Thank you for your assistance in this matter.
Regards,
Rob
ID:	317239   Click image for larger version
ID:	317240   Click image for larger version
Old 08-27-2018, 12:41:14 PM
Default Re: Metal Tractor Wheel or Metal Pulley? #2
This attachment shows the hole where a screw or a bolt goes in to secure the shaft to the rim and shows the number 1065 stamped on one of the rim spokes. Thank you for any assistance in identifying this rim for me.
Regards,
Robert
Old 09-17-2018, 12:50:46 PM
How much would be a good price for each of these 2 pulleys? I put $50 for each on ebay. Thank you. Rob
Rhodes 7" metal shaper needs a Step pulley/handwheel George Kulisiewicz Machine Shop and Tool Talk 11 01-25-2015 03:16:36 PM
Illinois G USA Metal Wheel Cart gfndtfs Farm Antiques and Collectibles 2 08-03-2014 08:58:16 PM
Pot Metal George Vaughan Hit & Miss Gas Engine Discussion 4 10-07-2012 09:34:34 PM
1918-1930 Antique Mack Truck Wheel Set rare metal spoke cushion tires Lilbethy Antique Autos and Trucks 1 04-09-2009 11:56:11 AM
pot metal Tim Rostar Hit & Miss Gas Engine Discussion 2 09-04-2005 08:13:55 PM
