Smokstak Down Under
Lister L 5hp @450rpm Central West NSW Newbie
this thread has 20 replies and has been viewed 938 times
Old 05-29-2019, 05:20:06 AM
Benno Benno is offline
Default Lister L 5hp @450rpm Central West NSW Newbie
Hi fellow Smokstakers,
Firstly, let me introduce myself. My name is Benno and I reside on a sleepy little property not far from Dubbo central NSW. I am 39 and over the past 12 months I have taken quite an interest in vintage stationary engines.
In that time I have purchased 3 Listers - a 6hp CS Diesel, 3.5hp AK Junior and last week a 5hp L series. I truly enjoy the simplicity and remarkable engineering of these engines. The reason for the interest in Lister engines is they are common and quite cheap and I grew up around shearing sheds and large properties for most of my earlier years.
For me, all my work bringing these (or trying) to life is a pure solo effort. My mates would rather tinker with their cars, and nobody else around here seems to interested. So, that leads me to joining the Smostak forum. Initially I was very hesitant, as I do not prefer social media, but Smokstak usually comes up when I am searching for a part or I am looking for advice on google.
OK , now that I have that out of the way, the reason I have started this thread is I need help with my latest purchase the Lister 5hp L. So calling all Lister guru's.....
Long story short. It's an older restoration and an ex-rally/show machine, been painted all pretty in green, on transport with cooling tank, and really looks the part.The main issue is that she's tired. Very tired. Compression is non existant. When I got her home, I checked valves and seats hoping it was a stuck valve or dirty seat, but no, so the cylinder was removed and it was found to have excessively worn rings. I wasn't expecting a 5.5" bore, I thought it would of been the same as the CS 6 at 4.5". Cylinder and piston are great.
Worn rings, gee this will be an easy fix....
5 days of searching, contacting Lister parts suppliers here down under and UK- no luck.
Rob at old timer engines (a fantastic guy to deal with) suggested this site and an older contact that I tried - no luck and possibly no longer available.
So, is there anybody at all that has or knows where I could locate a set - I am willing to pay good money. Alternatively I may need to get these made from a manufacturer but I will require the exact ring and cylinder specifications in order to have these made in which I can't find anywhere, and I don't have accurate enough tooling yet to measure myself.
Thankyou all who have taken the time to read this and with any luck someone, somewhere may be able to help me bring another engine back to life.
The Following 3 Users Say Thank You to Benno For This Post:
Old 05-29-2019, 06:23:44 AM
vs ss vs ss is online now
Default Re: Lister L 5hp @450rpm Central West NSW newbie
Hi mate, welcome aboard. I’m the same with social media this been pretty much one of the main sites I visit.
If you don’t mind a bit of a wait, I use ottos gas engine works or ottos ring spacers ( same place) in the us. Dave is good but due to work load you might have to send a second message. If you have a set of verniers, just measure the diameter, width and radial depth and shoot Dave a message. He will then make or supply a set for you and he has only ever charged me $5 a ring plus post. There are some other places over your way but you might have to wait for someone who is more familiar with that side of the country.
Cheers, mike.
Last edited by vs ss; 05-29-2019 at 06:26:46 AM. Reason: Don’t know what I’m doing.
The Following 2 Users Say Thank You to vs ss For This Post:
Old 05-29-2019, 06:41:37 AM
Famous Fitter Famous Fitter is offline
Hi Benno,
Welcome , Mike just beat me to it with the Otto contact.
There are many like minded people in your area, I am sure if you look up the local clubs you may find people with similar interests !!!
Be sure to stay in contact With Rob as you never know what he will find, he has helped me out heaps with all sorts of bits and pieces (and engines).
I’m of similar age to you and am not too keen on the social media side of things but this kind of forum is not too in your face, and I quite enjoy the fact that people are generally more helpful given a bit of time to reply.
Good luck with your projects
Cheers Justin
The Following 3 Users Say Thank You to Famous Fitter For This Post:
Old 05-29-2019, 06:53:35 AM
Ray Freeman Ray Freeman is offline
Providing the bore measures ok its an easy machining job to make the rings if you have access to a lathe or know a machinist. Heaps of info on the net. I have made them for all my restorations and for many others with good results.
The Following 2 Users Say Thank You to Ray Freeman For This Post:
Old 05-29-2019, 07:32:27 AM
ozfarm ozfarm is offline
I got my rings for the Lister J and D off GS burling
The Following 2 Users Say Thank You to ozfarm For This Post:
Old 05-29-2019, 07:50:47 AM
typak typak is offline
Go to the Smokstak 'Sponsors' page on this forum for the piston rings your looking for,
Starbolt Engine Supplies or Hit And Miss Enterprises will have them.
The Following User Says Thank You to typak For This Post:
Old 05-29-2019, 08:30:31 AM
Winchester Winchester is offline
I agree Ray ......I picked up some discarded truck cylinder liners ,also have a selection of smaller diam CI for Villiers and the like.
The Following User Says Thank You to Winchester For This Post:
Old 05-29-2019, 05:22:43 PM
Scotty 2 Scotty 2 is offline
Hello Benno.
You have some fine engines there.
First of all........
Cheers Justin
Gees you've had a hard life then. Just kidding
Try Don Reid at Vintage Engine Supplies. 07 3200 5382
Did you try the Lister bloke at Tamworth?
I always thought the standard size of the L piston was 5 1/2 inches and the stroke was also 5 1/2 inches
Any pictures of the mighty Listers Benno
Cheers Scott
The Following 2 Users Say Thank You to Scotty 2 For This Post:
Old 05-29-2019, 07:27:49 PM
Unfortunately the piston rings sold in Australia now for vintage engines are in the main of very poor quality, I would get them from the US, also usually at a lower cost than the local offerings.
Old 05-30-2019, 02:36:13 AM
Thankyou all for the great help. At least I now have a few leads and somewhere to start.
I'd prefer to buy/get manufactured local rather than abroad, but I guess availability will be the decider on that one.
As I mentioned earlier, I am very new to this and now I realise that I should equip myself with the appropriate tools...I've just bought a 2T engine hoist, block & tackle, some lifting slings to help move these things around. A set of verniers are on the way so I can get those rings measured.
Rob from Old timer engines is a valuable man especially with my CS.
Scotty, you mentioned a guy from Tamworth? I can't say I have heard of him. Tamworth is about 3 hours from me, so quite conveinent if I need large parts.
Heres a couple of photos, the CS currently has the head removed as it was severely pitted around the exhaust valve so she keeps blowing head gaskets, the little Junior is a little ripper, and the 5hp L is the newest addition , just got its cylinder off atm while I sort the rings out.
I prefer the engines original unpainted, as I like the "working clothes" look, so the junior and CS will stay as they are, and eventually I will take the L to a few fairs once I have things in order.
ID:	335884   Click image for larger version
ID:	335885   Click image for larger version
ID:	335886   Click image for larger version
The Following 5 Users Say Thank You to Benno For This Post:
Old 05-30-2019, 03:18:15 AM
Motorbike.....what motorbike?? I didn't see a motorbike did I? Yeah I did
In Tamworth try Brian Wells on 6760 8276
I like the original finish on your engines. You can't remake that.
And thanks for the pictures.
Cheers Scott
Old 05-31-2019, 02:28:40 AM
cobbadog cobbadog is offline
Welcome Benno,
You are about to or already have been bitten by the bug so start making more room for more engines.
Can I make a suggestion if you are not doing it already. In one of your pics you have a single sling under the engine. Please use 2 slings as this will stabilize the lift and no tipping over.
You have a nice selection of toys already and hopefully you can have them all running very soon.
Cheers Cobba
Old 05-31-2019, 05:44:09 AM
G,day Cobba, nice to meet another fellow New South Welshman from the site
Yeah the bug bit me a couple of years ago when I helped my firewood buddy repair an old side valve 9hp briggs that is still in use today on a sawbench!
Since then I have never looked back....
Re the sling - The little junior that you see was just pulled forward off the side of the shed so I could fire it up last weekend on that thick rubber mat, and I only lifted it a couple of inches of the ground on my engine hoist. I have wondered about the safest way to lift these - especially onto a high ute or such. Is it true that you shouldn't lift just using the flywheels? I normally use that one sling (2T) underneath as you see and stabilise with a rope through both flywheels back onto the lifting hook if she needs to go high.
I would certainly hate to see one of these drop from any height
Old 05-31-2019, 05:21:19 PM
Yes. True. Many a crank has been bent by lifting by the flywheels.
So.....what's the story with the motorcycle Benno?
Cheers Scott
Old 05-31-2019, 05:30:52 PM
mihit mihit is offline
Yes this. A bit of CI pipe on the lathe, and you're away. If you can't do it yourself it's probably a "2 box" (of beers) job depending how close the pipe size is to bore/piston and so how much material is being removed.
The Following User Says Thank You to mihit For This Post:
Old 06-01-2019, 02:52:15 AM
I ain't no machinest, let alone posess the skills to manufacture such parts. I certainly wish I could though , as I can only imagine what cool stuff I could make.......
If anybody here would like to make these for me to save me making calls and emailing....be my guest. I'll pay 3 cartons
I am in negotion now with a munufacturer from UK that specialises in making piston rings and is familiar with the Listers engines. Hopefully pommy steel is still ad good as what it was 80 years ago!
Old 06-01-2019, 02:59:53 AM
Default Re: Lister L 5hp @450rpm Central West NSW Newbie
This is probably getting off thread.....
Scotty this is for you.
1940's something Royal Enfield RE125 aka "flying flea".
I've had this girl for years and is one of the last remaining vintage bikes I own as I sold the rest a few years ago. I've done a full mechanical rebuild, and have the original seat tucked away because like the bike, she's gettin very fragile.
Runs & rides, heaps of fun....good old smokey 2 stroke...
ID:	336048   Click image for larger version
ID:	336049   Click image for larger version
The Following 4 Users Say Thank You to Benno For This Post:
Old 06-01-2019, 03:05:34 AM
I would purchase them from Starbolt, off the shelf.
https://www.enginads.com/starbolt/catalog.pdf
The Following 2 Users Say Thank You to typak For This Post:
Old 06-01-2019, 03:06:52 AM
I would be sourcing them locally. A couple of places mentioned earlier should be able supply.
Love the bike too. I rode one from Bathurst to Rockley once in the middle of Winter. Went straight to the pub to thaw out, as you do.
Old 06-01-2019, 05:00:15 PM
Hello Benno
Thanks for the other pictures and brief description of your motorcycle.
Mate. Now I see the old firefighting cart. You gotta get some back drops to stop nosy old farts, like me, seeing what you have
Cheers Scott
PS: I'd be surprised if Don or Brian didn't have your rings.
New guy to the Stak, West central Illinois Hard Core Deere Man Smokstak Forums Meet and Greet 7 08-04-2014 07:22:29 PM
West Central Ohio Swap at Urbana OH Mark Shulaw Shows and Swap Meets 13 02-26-2013 03:55:57 PM
Engine Show in West Central Indiana Randy Nichols Hit & Miss Gas Engine Discussion 10 04-16-2012 09:51:41 AM
West-Central Illinois Auction Prices, August 2010 Timberedge1 Hit & Miss Gas Engine Discussion 2 10-07-2010 11:44:26 PM
Newbie from West Texas Tractor79765 Smokstak Forums Meet and Greet 0 07-02-2010 10:28:00 AM
