Smokstak Down Under
Loctite
this thread has 26 replies and has been viewed 1381 times
Old 05-28-2019, 06:34:15 AM
AussieIron AussieIron is offline
Default Loctite
Is it just me? - Why do Loctite products ( Stud loc, 404 etc.), come in those stupid little plastic bottles that are top heavy,even when full, and tip over and leak, even with the top done up as tight as possible? Maybe they're smart, it may be a ploy to make you buy more than you use?
The Following 4 Users Say Thank You to AussieIron For This Post:
Old 05-28-2019, 05:51:47 PM
Scotty 2 Scotty 2 is offline
Default Re: Loctite
Oh how I can relate to that. I ended up putting them in a small tin where they couldn't fall over. I also got the big round economy size bottles on some of the products. They tend to fall over less often.
I'm sure the shed gremlins open those lids and push those little bottles of gold over.
Cheers Scott
Old 05-28-2019, 09:31:20 PM
karragullengine karragullengine is offline
Default Re: Loctite
Maybe its to help get into awkward areas. Would be interesting to know their reasoning behind it. Never given it any thought, i just keep it on shelf behind a tin so it can't fall.
The Following 2 Users Say Thank You to karragullengine For This Post:
Old 05-28-2019, 09:42:44 PM
typak typak is offline
Default Re: Loctite
Never used loctite, don't see any reason why you should use it? if you put things together properly......
The Following User Says Thank You to typak For This Post:
Old 05-28-2019, 10:03:56 PM
Default Re: Loctite
You've obviously never owned a berti mulcher/flail mower!!
Old 05-28-2019, 10:43:45 PM
ulgydog56's Avatar
Default Re: Loctite
ya and you ether get to much or to little when you squeeze it....
Old 05-29-2019, 05:12:15 AM
davob davob is offline
Default Re: Loctite
Depends on the application Typak. For our old engines and tractors I'd agree with you but when it comes to industrial applications I believe you are wrong. There are numerous instances in the equipment I'm involved with where the OEM manuals state some kind of Loctite product use is required during assembly. These can be components that have high levels of vibration such as rock drills and breakers down to the likes of industrial automatic transmissions where temperature cycles and differing expansion rates of dissimilar materials may cause fasteners to eventually loosen. Just my opinion
The Following 3 Users Say Thank You to davob For This Post:
Old 05-29-2019, 09:07:11 AM
Default Re: Loctite
It's common to see Loctite throughout automobiles today.
Old 05-29-2019, 09:34:30 AM
Tracy T Tracy T is online now
Default Re: Loctite
and from the factory. anybody ever ran into that green version? I have one time, and i believe it was a suzuki. damn thats some mean stuff!!!
Old 05-29-2019, 10:28:43 AM
Default Re: Loctite
This is an Australian thread, brings this to mind. My brother worked for the Austoft, now Case-IH dealer when they first imported the harvesters. We were introduced to a product called Araldite, a thick two part epoxy locking compound, mandatory on all bolts during assembly, good stuff.
Old 05-29-2019, 10:31:37 AM
Fred Van Hook's Avatar
Images: 480
Default Re: Loctite
Yes and used with the activator when its set its impossible to release without heat..
A Atheist will never be able to say, "I told you so!!"
Engine movies can be seen at: pileofiron
The Following User Says Thank You to Fred Van Hook For This Post:
Old 05-29-2019, 12:26:13 PM
gnucklehead gnucklehead is offline
Default Re: Loctite
We had these cheap power supplies once, the front panel potentiometer nuts kept working loose..
"put little dab of loctite on them" I told my colleague.
Old 05-29-2019, 05:04:21 PM
asw20 asw20 is offline
Default Re: Loctite
That green stuff is certainly good. Keeps the steering arm studs from coming apart on my International ASW120 (S120 4x4 in the US / Canada). Every front axle I pulled apart was damaged there (under sized for the job).
Jarrod.
Old 05-29-2019, 06:34:42 PM
Winchester Winchester is offline
Default Re: Loctite
Yes well I once had occasion to repair a mans dentures with Araldite.
The Following User Says Thank You to Winchester For This Post:
Old 05-29-2019, 09:31:46 PM
Default Re: Loctite
that green version i ran up on was on tork converter bolts, i was working with a combination wrench. the other guy on the other end of the engine had a 1/2" breaker bar and a cheater bar trying to hold things still. he yells out how the blankety blank are you getting that much force on that nut!!???? In other words he was having one hell of a time dealing with the force i was exerting on the nuts with bigger tools on his end! yes sir good s#$t!!!!!
Old 05-30-2019, 04:49:13 AM
Default Re: Loctite
Tracey T
Sounds similar to the stuff Caterpillar used to sell as a gasket cement. They discontinued it years ago but it was commonly called Cat Green in the trade and sold under part number 5H-2471. Great stuff when you were putting things together, but horrendous when pulling it apart again later on. Had a pressed tin sump on a 3306 Cat once that someone previously had put on with Cat Green on both sides of the gasket. By the time we managed to get it pried it off the block that sump was almost unusable
Old 06-01-2019, 07:37:52 AM
Tranter Tranter is offline
Default Re: Loctite
Had an education by the Henkel rep on this many moons ago..
being Loctite is an anaerobic (meaning it goes off due to the absence of Oxygen) the bottles are actually made out of a semi porous plastic which enables them to "breathe"
as to the shape, they are design to fit in the pockets of toolbags and toolboxes easier... so there you go...very unexciting stuff..
The Following User Says Thank You to Tranter For This Post:
Old 06-01-2019, 05:28:04 PM
Default Re: Loctite
Hello all
Does anyone remember the bottle of goop that Holden recommended to be used on head bolts on Holden engines? It was used to seal the bolts etc that screw into the water jackets. I have a bottle here (if I remember where it is. I got to clean up) I still like to use on head bolts that go into water jackets.
Cheers Scott
Old 06-01-2019, 06:59:30 PM
Default Re: Loctite
I remember Permatex or something like that. It was in a tooth paste type tube that always leaked too.
Old 06-01-2019, 08:16:42 PM
Default Re: Loctite
Not sure what that product was but i love loctite 567. Any fuel or water leaks and that stuff stops it in its tracks. It doesn't set hard so easy to remove. I put a thin layer on gaskets for oil and water applications and they never leak. It is great on air compressor and gas fittings too as it can take high pressure and as it doesn't set hard really easy to remove and clean for reuse.
The Following User Says Thank You to karragullengine For This Post:
Gasket Sealer and Loctite on bolts? enginesilo Maytag Engines and Collectibles 10 12-10-2012 11:15:18 PM
Removing high strength loctite lester Antique Engine Archives 7 03-26-2003 12:54:15 PM
