Onan GenSet - project rebuild
this thread has 59 replies and has been viewed 2920 times
Old 06-19-2017, 08:20:40 AM
gmdoctor gmdoctor is offline
Default Onan GenSet - project rebuild
I've been looking for a generator for a good backup for my house/shop for years. The newer models (cheap ones), never seem to last. I'm here in the panhandle of Florida and it seems we have more power outages than i have ever experience. Last week i came across an older Onan and it was nearly fully intact. Mice have made a home in it for quite some time, and have enjoyed the wiring and insulation. Long story short, i got the engine running on propane, but i have nothing to test the genset portion. i will post pics as i can. Model No. 15.0JC-18R/15026AB and Serial # K830684756
As far as i can tell it has a build date of 1983. The carb looks like it was submerged in the gulf for years (appearance only) so gas will not move through it. If anyone can help me locate a good schematic for this i'd be eternally grateful. The engine side i can just about figure out, but reference material is always great to have around. As for the Gen side, i am totally dependent upon the masters in here. but i just need to get this thing cleaned up and running again. Anyone have a good source for parts for these older sets? I'd love to find a reliable source. Thanks in advance!!
ID:	284713   Click image for larger version
ID:	284714   Click image for larger version
ID:	284715   Click image for larger version
Old 06-19-2017, 08:42:35 AM
Billy J Shafer's Avatar
Default Re: Onan GenSet - project rebuild
Look at the amp meter. If it is charging it is producing power. How much you will need a volt meter to find out. Give us time we can get you all the manuals and information you need. I would leave it on LP/NG. The gasoline side can be a pain sometimes.
Onan Parts is a seller of parts on this site.
Old 06-19-2017, 09:10:42 AM
Thanks for the quick response Billy. I am a firm believer in OE parts. And i didn't look at the amp meter when i got this thing to run before i started to pull it down. I noticed it having a bunch of parts missing and thought it best to see what i may need to fix this before i put it into use. It has a bunch of wire emanating from the generator. they are separated and tied into 4 groups. i am leaving this for a later time to get straight.
Old 06-19-2017, 09:12:34 AM
Ray Lynch Ray Lynch is offline
gmdoctor
Welcome to the site.
Manuals are available at the attached link. Do not run the set more than a few minutes without having the side tins installed. Otherwise it could overheat.
Good luck with your set.
Ray
http://www.twinslan.net/~n0nas/manuals/onan/
The Following User Says Thank You to Ray Lynch For This Post:
Old 06-19-2017, 09:19:07 AM
Kevin K Kevin K is offline
Your model 15.0JC-18R/15026AB doesn't show up in my database, but a 12.5JC-18R/15026AB does. They are most likely the same machine, but yours has a 15Kw generator end. The good news is your has an extended stack, which gives you the full 15Kw on single phase.
I have attached the build sheet for the 12.5JC-18R/15026AB. I would guess the wiring diagram should be the same for your machine.
The Following 4 Users Say Thank You to Kevin K For This Post:
Old 06-19-2017, 09:21:28 AM
Thanks Ray, good advice. I never let it run more than a min. I just wanted to see if it would run at all. Thanks for the link!
Old 06-19-2017, 09:23:46 AM
Did you pull the voltage regulator cover off and then pull the voltage regulator off the control box to look for mice damage? I know you said you found some but didn't say where. They also like it inside the generator end, you might pull the end bell cover off along with the little rectangular mesh cover off the charge resistor and blow it out real good with air if you already haven't.
I just recently bought a 15.0JC but, mine was three phase and not extended stack like yours and in single phase it's only good for 12.5KW.
The control box and V/R were all good but, the gen. end had a lot of stuff in it!
The Following User Says Thank You to nothingbutdarts For This Post:
Old 06-19-2017, 09:30:53 AM
Kevin, that's awesome thank you. Once again though, the genset being stacked i wouldn't know the difference. I have never had any schooling on this. small portables are easy to fix. this set is foreign to me.
i pulled it down and found one wire completely chewed in half, and another one with no insulation let on it. the later was to the starter.
Old 06-19-2017, 10:44:49 AM
As for pulling the bell end, i haven't gotten that far yet. Do they make replacement harnesses for these models? If not i can make my own. I have a bunch of pictures of everything, but i don't see where i can post more.
Old 06-19-2017, 10:51:44 AM
len k len k is offline
Sounds extended stack (good), nameplate says at 120/240 can make all 15 kw on single phase (62.5 amp rating). Likely a 12 wire genhead ( 6 winding) so have to wire it right to get that 15kw on single phase.
I see a propane tank fitting stuck in the vapor fuel line to carb. It can work if you do a lot of continuous tweaking of the tank valve to get flow to follow electrical load during testing .
But for actual use your going to need a pressure regulator to reduce propane tank pressure down to ~ 11 inch W.C. pressure. Then pipe that to a demand regulator, which will flow fuel proportional to engine's needs.
Tri-fuel carb on my similar 7.5 kw JB had all the idle adjustment screws froze from rust. Took it apart and CAREFULLY heated aluminum casting at the screws and was able to work them out and wire wheel rust off them. Aluminum expands 3X faster then steel screws. I put them back in with anti-seize. Need to not overheat the aluminum, it melts without notice, doesn't glow red. Think even a propane/air turbo torch can get you to melting temp, so have to be carefull.
Huber 18-36 wheel rebuild project - need measurements Bryan Donaldson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 24 09-16-2016 11:53:00 PM
Tecumseh AH-47 rebuild and CAD project Revitup Small Air Cooled Gasoline Engines 5 12-13-2012 08:59:14 AM
IHC M rebuild project JLee1988 Antique Gas Engine Discussion 6 10-13-2010 12:14:57 PM
Kolher Genset Rebuild...wow, what a job.... ReadyKW Kohler Generators 12 10-01-2006 08:51:11 AM
Waukesha ICK67C military genset - nasty engine project. Mac Leod Military MEP and Aircraft Gen-Sets 28 08-31-2006 04:20:42 AM
