Onan JB Thermomagnetic Choke
this thread has 109 replies and has been viewed 3578 times
Old 08-13-2017, 10:08:18 PM
JoeE. JoeE. is offline
Default Onan JB Thermomagnetic Choke
Just got this unit. Hadn't run in a long time.
Mod. 7.52B, serial 0173550945
JB 3CR 8389T.
Moving it, one of the connections to the coil on the thermomagnetic choke got broken off.
I removed it and got it reattached and soldered the wire back to the lug.
I made a hasty drawing of the wire connections as they appeared before I removed the coil, but I find it was not detailed enough now.
As you can see by the drawing, there appear to be 4 connections on the body of the coil itself. After disassembly, I determine that only two of the connections actually go to the coil winding itself.
The other two have no wire connection to the coil itself and just connect whatever two wires you connect to it, to themselves. I have highlighted them green on the drawing. The actual coil connections are indicated by red lines.
Anyhow... I'm not sure I got the wires all back on the lugs they came off of.
One from the bimetal strip is labeled H and one G. None of the other wires that came off it are labeled. Two wires had covers over the female lugs and the others are bare lugs.
Neglected to take photos of the set, but can do that later.
I just can't envision the path the voltage takes in this at startup or else I may be able to figure it out myself.
Don't think the machine has low oil cutoff protection.... there is no pressure switch down at the oil filter housing.
ID:	288530   Click image for larger version
Old 08-13-2017, 10:20:26 PM
JohnnyC JohnnyC is offline
Default Re: Onan JB thermomagnetic choke
Attached are 2 pictures that you forgot to take. I hope they help.
JohnnyC
New Jersey
ID:	288535   Click image for larger version
The Following 4 Users Say Thank You to JohnnyC For This Post:
Old 08-13-2017, 11:55:55 PM
Default
Thanks.
That's the same animal. The two wires that go on the other lugs come from up in the control box, or whatever it's called.
Right now, the choke butterfly is seized in the housing and won't move, so I'm working on that... then I'll see how the entire thing works.
This thing needs some TLC... the external wiring has been cobbled together.. I'm just plodding along trying to decipher what they've done.
It was built into a mobile office .. like a mobile home... and powered some rooftop air conditioners.
I disturbed the adjusting linkage on the governor... not knowing what I was doing trying to get the vacuflo shroud off the front of the engine... have to get all that cleaned up and reassembled... hopefully I didn't mess up too much.
Anyhow... babysteps.
Old 08-14-2017, 12:51:44 AM
All the manuals you need are here:
http://www.twinslan.net/~n0nas/manuals/onan/
Your model is a 7.5JB 3CR/8389T
I'm pretty sure it was built January of 1973 from your posted serial #
I also believe it might be a magniciter generator end. If so there are precautions you need to take to make sure the engine is running @ 1,800 RPM or it could let out the magic smoke! But that's sounds like it's a little further down the road for you!
The smart guys are here to help!
Old 08-14-2017, 01:07:12 AM
len k len k is online now
When terminals on my choke broke out of the weak paper I silicone rubbered them back in place and physically secured them with tie wraps. I didn't put much silicone rubber on it since that would interfere with coil cooling, The 1.7 ohm coil draws a lot of amps (~ 5-7) while starter is cranking, so that's a high ~ 50-80 watts of power dissipation
Old 08-14-2017, 05:08:26 PM
Alrighty then.
Read thru some of the manuals I'd found online. Once in a while it'd say something like "produced after series P" or something like that.
I don't understand how a guy is to discern which production model letter series he may have,from the assortment of letters in the serial and model number.
In the control box atop the generator housing, it still has electrical relays and all the original stuff up there. On youtube, I've seen some that I take it that have more modern solid state equipment mounted up there.
Is that possible with this age of machine, or are only the newer versions of Onans capable of being fitted with that new stuff?
One other question.. . how come we (or maybe it's just me) can't "edit" my posts?
Old 08-14-2017, 05:44:56 PM
KPack KPack is offline
You have to be a member for 20 dollars to be able to edit
Old 08-14-2017, 06:34:04 PM
grif grif is offline
That's why the list exists... and gives the smart guys breathing room from us rookies, and we get to glean their experience with a few nice comments and thanks as payment, with just a few keystrokes!!! I'd make a Ford/Onan comment about daily changes in production but somebody would take me to task ;-)
And it gives people like me affordable reading material.
Old 08-14-2017, 06:52:43 PM
The last letter in the model number, in your case "T" is your spec. letter.
Your set has a magneciter to regulate voltage, Leon can expand more on that subject and you can read about it in one of the sickies at the top of this forum. The newer J sets have an electronic voltage regulator on top of the control box.
The Following User Says Thank You to Max Thompson For This Post:
Old 08-14-2017, 07:15:47 PM
On some gens that came with an electronic voltage regulator on top of the control box owners have sometimes replaced them with a cheaper generic SX460 reg.
Onan LK Choke Phenomena KidDynamo Onan Generators 6 06-16-2015 09:16:09 PM
onan 6.5nh 3cr choke in pieces RonWSL Onan Generators 7 11-17-2014 11:03:37 AM
onan 2.5 lk electric choke gets hot.. YellowLister Onan Generators 4 02-16-2014 03:38:24 PM
Onan choke adjustment? MadMachinist Onan Generators 5 02-12-2012 11:05:21 PM
Onan Choke Assembly CurtisFoley Onan Generators 6 10-09-2008 11:01:15 PM
