Onan 7.5 HDKAJ Code 3-13
this thread has 27 replies and has been viewed 1497 times
Old 09-01-2017, 03:51:20 PM
155mm 155mm is offline
Default Onan 7.5 HDKAJ Code 3-13
I have read thru, I hope, all of the HDKAJ posts and didnt see my error, so if there is a thread please point me in that direction.
Have a new to me camper,
and it had this genny in it, with about 430 hours on the meter, HDKAJ ... C
The problem I am having, it runs just fine until the outside temp is above 85*F, then it shuts down. Flashes 3-13.... 13 is undervoltage. The genny will do this code even when the breaker is shut off and the engine is cold. When the jenny runs, there is no issues pulling both AC units and the microwave all at the same time.
I dont know if the outside temp has anything to do with the shut down code, just giving all the info that I have.
The genny is buried in the front of the camper, so I have to plan on disassembling the front of the camp to work on it.
It had a full service done (air filter, oil filter, oil, fuel filter, water pump belt, coolant tested) about 30 hours, 3 months ago.
Old 09-01-2017, 03:59:23 PM
len k len k is online now
Default Re: Onan 7.5 HDKAJ Code 3-13
Your gen is spec C, made July of 1996
Looking at schematic on pfd page 92 of service manual looks like this gen is an INVERTER type.
I see that it has a water temp sensor, could check that connections to it are clean.
Link to manuals on it.
http://www.twinslan.net/~n0nas/manuals/onan/
When in link press control-F bring up search mode. type in hdkaj and search on it
Should bring up several manuals, service, parts , install, operator.
Read the service manual. Error codes as usually at rear of manual.
Old 09-01-2017, 05:26:53 PM
BigBlockChev's Avatar
Could be something simple like a loose belt, there is no belt tensioning as such just 2 pulleys. I would also be checking that the rad is clean and there is no debris buildup impeding airflow. If you get the unit out it is fairly easy to get the panels off to access the internals. I have a HDKAT that I resurrected from the dead with a 1$ MOV. The question is , is the code the cause or the effect, ie is it shutting down because of under voltage or is it observing undervoltage as it shuts down from some non specified/monitored condition. I had this issue on another computer controlled Onan gen. Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
The Following 3 Users Say Thank You to BigBlockChev For This Post:
Old 09-01-2017, 07:27:25 PM
It is acting the same, before and after the belt change, the rad was clean enough to see thru.
Old 09-11-2017, 10:28:47 PM
timaz timaz is offline
Does anyone have a link for a hdkaj service manual that works? I have a intermittent code 11...over current.
timAZ
Old 09-11-2017, 10:39:16 PM
Link has been down for a few days, server issues.
Read this , another link to manuals is near end.
https://www.smokstak.com/forum/showt...=155507&page=2
Old 09-11-2017, 11:27:24 PM
thank you, but the only thing that comes up when I search for hdkaj is a spec sheet.
TimAZ
Old 09-12-2017, 05:50:08 AM
Kevin K Kevin K is offline
The server issue is taking longer than we expect, and the temporary Google drive page is missing many of the files. I can send you the manuals by email if you wish, just PM me an email address that can accept large attachments.
981-0161 Operator
981-0200 parts
981-0514 engine service
981-0522 Generator service
981-0623 install
The Following 4 Users Say Thank You to Kevin K For This Post:
Old 09-12-2017, 07:12:21 PM
Thanks again for your help Kevin!
Is there anyone on here with information to pin-out the inverter-controller. The manual only states to replace it. I'm that is very pricey.
Thank you for your help,
TimAZ
Is there anyone on here with information to pin-out the inverter-controller. The manual only states to replace it. I'm guessing that is very pricey.
TimAZ
Old 09-12-2017, 11:50:22 PM
I got one with a failed inverter/controller turned out to be a $1 MOV had failed. I would definitley take the inverter out and give the circuit board a visual check for cold solder joints , bulging capacitors or burnt components. If you have a buddy who is good with electronics it would be a good idea to have him have a look at it for you. They are actually fairly well made and the components are not too hard to get at just a million screws to get it out. Cheers Dan
The Following 2 Users Say Thank You to BigBlockChev For This Post:
Onan 7500 HDKAJ stops, shows 3-11 code Pusherpilot Onan Generators 9 11-10-2013 09:11:04 AM
Onan 7500 HDKAJ Onan wont turn over/start md00738 Onan Generators 7 11-04-2013 09:09:30 AM
Onan 7.5 HDKAJ Lew in Florida Onan Generators 3 09-12-2013 08:52:12 PM
Onan 7.5 HDKAJ Problems KIX Onan Generators 11 02-10-2010 10:50:27 PM
Onan 7.5 HDKAJ Peter Parry Onan Generators 2 10-30-2007 09:07:43 PM
