03 Onan 7KW Marquis in Motorhome
this thread has 11 replies and has been viewed 464 times
Old 09-08-2017, 11:23:26 AM
Cruiser Cruiser is offline
Default 03 Onan 7KW Marquis in Motorhome
My genset will run until it gets hot outside, 90F +. Then it shuts off and will restart Then starts searching and quits again. Oil is full and cleaned air return on bottom of unit. Any ideas would be appreciated!
The Following User Says Thank You to Cruiser For This Post:
Old 09-08-2017, 12:47:08 PM
len k len k is offline
Default Re: 03 Onan 7KW Marquis in Motorhome
Need full model and serial number to know what you have, onan made a lot of gens.
"Starts searching" ........ do you mean rpm is hunting?........ rpm bouncing around with a no change in electrical load.
Is 120 V voltage output constant ?
Old 09-08-2017, 01:19:21 PM
Model# 7HGJAB-900B Serial# K020441355
---------- Post added at 01:19:21 PM ---------- Previous post was at 01:14:50 PM ----------
The RPMs of unit will actually start to slow down. Then before it shuts down it will start almost acting like it's starving for fuel.
Old 09-08-2017, 03:33:05 PM
spec B, Made Nov of 2002
With steady electrical load, when it's losing rpm check throttle position. If it's ~ WOT then it's likely starving for fuel. Fuel supply problem.
If squirting a little stream of gasoline down carb throat brings rpm back up it is a fuel supply problem.
Good to not let it shut down with large load on it, AC voltage regs don't like that. Stresses them, can die eventually
Also check that hot exhaust cooling air is not being sucked back into cooling air intake. Might need some sheet metal between the 2 openings to prevent that.
The Following 2 Users Say Thank You to len k For This Post:
Old 09-08-2017, 06:40:43 PM
Was gonna change oil plug and fuel filters. Figuring it might be a over temp sensor
Old 09-08-2017, 06:46:34 PM
I don't see an eternal temp sensor in schematic at back of service manual for HGJAB.
Could be one internal to control board though, but pervious models like 6.5 NHE, 7NHM didn't have temp shut down.
But would guess it would display a fault code if shut down on over temp. Flashing LED.
I gave a very breif skim of trouble codes in back of service manual, didn't see code dedicated to only over temp.
Manual number and link to them.
HGJAA HGJAB HGJAC HGJAD HGJAE HGJAF ----SERVICE---- (01-06)--- 983-0501D.pdf <--read this one
HGJAA HGJAB HGJAC -vert shaft (sepc A-C))--- PARTS--983-0201D.pdf
http://www.twinslan.net/~n0nas/manuals/onan/
Link has been down for past few days , server issues. might be up tonight. Info on that here
https://www.smokstak.com/forum/showthread.php?t=155507
Old 09-08-2017, 11:19:41 PM
I'm thinking maybe vapor locking or fuel pump is loosing pressure when gets hot? Tuning it up tomorrow with plug oil fuel filters. Would 91 Octane be better to run in the hot weather.
Old 09-09-2017, 09:03:37 AM
Oldchvys Oldchvys is offline
If you are thinking it might be vapor lock, a quick way to check is to disconnect the fuel supply from the coach and run the genset from a gas can. From the way you described it, it does sound like a fuel pump problem though.
The Following User Says Thank You to Oldchvys For This Post:
Old 09-09-2017, 10:10:05 AM
I've no experience with vapor lock.
If RV is stationary as a test might even get a sheet of plywood or something between hot cooling air exhaust and cooling intake, to prevent recirculating hot air into intake. Make sure it doesn't touch or is too near anything hot that may make it catch fire.
Old 09-10-2017, 01:00:10 AM
Doug Reed Doug Reed is offline
TwinsLAN is still down. I have many of the files on Google Drive and will copy the rest when TwinsLAN comes back. Use this link for Google Drive. I did see both of your files there.
https://drive.google.com/drive/folde...28?usp=sharing
Onan 6.5NH5CF/16004P in our motorhome, not working teamf4 Onan Generators 90 07-27-2015 07:31:25 AM
Onan 205 LK RV6000 1G 1971 Dodge Motorhome sgtteko Onan Generators 2 09-14-2013 09:51:18 AM
Onan 6.5 in motorhome - oil comes out of oil fill hole when off Sanddune Onan Generators 10 09-03-2013 06:31:48 PM
Onan Generator won't start unless the motorhome is started first wurtzracing Onan Generators 19 05-14-2013 02:15:46 PM
4KW Onan Genset 1976 Argosy Motorhome johnw10257 Onan Generators 12 04-24-2010 11:34:58 PM
